Old 12-09-2007, 10:31 PM
SteveMcqueenRules's Avatar
SteveMcqueenRules SteveMcqueenRules is offline
Default A-Body Suspension Rebuild
I need to buy a front suspension rebuild kit and would like to hear some recommendations of a company.
Should I go with Polyurethane Polygraphite or Rubber bushings?
You're gonna be hangin' on for mercy when I get this sucker rollin'- FALFA
Old 12-10-2007, 07:11 AM
camcojb camcojb is offline
most popular suspension companies use a urethane or poly bushing in their components like http://www.p-s-t.com/
Old 12-11-2007, 09:48 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Do a search over on Team Chevelle.
For optimum results different bushings points, need a different bushing material or type of bushing.
Old 12-11-2007, 09:51 AM
fesler's Avatar
fesler fesler is offline
The biggest thing to consider that most guys doing this dont is that the Poly Bushing will sqeek after time and the Rubber ones wont. Most of the companies dont mention this but if sqeeks bother you order what will be best overall for your application. They are both good in their own ways.
Chris Fesler
Fesler Built - Scottsdale, AZ
Old 12-11-2007, 08:38 PM
sinned's Avatar
sinned sinned is offline
Rubber is overly compliant and poly won't allow any articulation in the rear, is prone to cold flow issues, squeaks (which is big time annoying over time), and still allows movement in critical areas.
Look into a Teflon derivative like Del-a-lum or seek out SC&C for their version.
Dennis
Old 12-12-2007, 09:08 PM
polygraphite wears out due to the graphite
polyurethane squeaks
rubber is too soft
So if i am diligent about greasing the bushings with the polyurethane I assume they wont squeak?
I was looking at a kit from PST $419 for the super polygraphite front end rebuild kit http://www.p-s-t.com/pc-3786-30-chev...o-1964-88.aspx
I read a bunch of stuff over at teamchevelle and could not come to any conclusion. Does polygraphite really deteriorate like I have heard? And if it has graphite wouldn't that stop the squeaks?
Old 12-12-2007, 09:21 PM
Vince@Meanstreets's Avatar
I never had any luck with the graphite stuff...but I had a lot of miles on that build.
But you are correct, lube them good to start and they stay quiet. Energy suspensions has the lubing channel built into them to keep the lube evenly dispersed.
Old 12-13-2007, 05:35 AM
DHARROD's Avatar
DHARROD DHARROD is offline
I've used Energy Suspensions on three chevelles .. in NC so perhaps its warmer and thus I have never had squeeks (one car has been restored for one year now). Got the kits from Jegs I think. Perhaps the squeek is there but with flow masters and a BBC I can't hear anything but engine. I've seen cracks develop in rubber in less than 3 years on a friends restoration .. he now has to replace them.
Old 12-13-2007, 11:30 AM
Don't tell me, in the upper control arm bushings. Never fails. We did a Camaro and the stock type rubber just fell apart (6 months) and the control arm shaft came loose.
Old 12-13-2007, 02:50 PM
ok let me check out those energy bushings. Its good to hear from someone who has something more than speculation. Thanks!
