Old 06-27-2005, 01:04 PM
ProTouringNyC's Avatar
ProTouringNyC ProTouringNyC is offline
Default Rock Valley problem (fumes)
Hey guys got a problem I have a rock valley tank just wanted to know if anyone added a charcoal canaster or some kinda check valve. Im loosing my mind ive tryed fuel hose with a twist in it it still leaks and i still smell the fumes any help would be greatfull im sure others have the same problem thanks Carl
Old 06-27-2005, 01:08 PM
907rs's Avatar
907rs 907rs is offline
Do you have a vented cap?
Bill
Old 06-27-2005, 01:14 PM
XcYZ's Avatar
XcYZ XcYZ is offline
I ordered my tank from Rick's Hot Rod Shop with a vent line that will be getting a charcoal canister attached to keep the fumes in check. I'd go that route.
My LS7 69 Camaro
Old 06-27-2005, 01:20 PM
rockdogz's Avatar
rockdogz rockdogz is offline
Scott,
Do you have a part # for that canister? Trying to track one down myself
-Tom
camarorestoration.com
Old 06-27-2005, 05:43 PM
Steve1968LS2's Avatar
I caped off the vent tube and ran a vented cap..
Had a hell of a time trying find a charcoal canister and the gas kept sloshing out the vent tube (bad location)..
Old 06-27-2005, 07:50 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
is the deal on yet?
Jim
Old 06-27-2005, 08:15 PM
XcYZ's Avatar
Yes it is, Jim:
https://lateral-g.net/forums/showthread.php4?t=1248
My LS7 69 Camaro
Old 06-27-2005, 08:54 PM
Hey Steve1969LS1 do u have a rock valley tank if so which gas cap did you get cant find one anywhere thanks
Old 07-04-2005, 08:28 PM
I have a custom Rock Valley tank in my EFI 427 small block 56 Nomad -- and always smelled like gas in the garage after cruising... I've done everything I could think of to figure out where the "smell" was originating from.... now you guys have given me a clue! Never thought about the vent tube - and I have an UNVENTED O ringed thread cap! DUH!
Old 07-14-2005, 11:53 PM
GO67SS GO67SS is offline
Default Canister
Greg, did you find or add a charcoal canister yet. I spoke with Hector and Ricks hotrods where I bought my fuel tank. Awesome piece of work . He said it was a must to limit that fuel smell. I haven't yet picked up a canister or figured how to install it. I guess I will need to run a vacuum line to the rear of the vehicle or a vent line to the front of the vehicle. either way I will have to run a long line in one direction.
Drive it like you stole it!
