Old 04-16-2008, 08:11 AM
kennyd's Avatar
kennyd kennyd is offline
Default stock ls intake
looking for a stock intake, fuel rails and throttle body for LS motor . i have a 5.3l i need to install in a rockcrawler but i need more hood clearance .
i plan to use the injectors sensors and wiring on the 5.3 . will it work ?
Old 04-16-2008, 09:39 AM
Jr's Avatar
Jr Jr is offline
ls1tech.com would be the best place for your wiring question. If you are looking for a stock intake, I would go with a ls6 intake. The ls6 flow a little better than the stock ls1 intake.
conversions and hybrids forum
http://ls1tech.com/forums/forumdisplay.php?f=28
Hope this helps
David
Old 04-16-2008, 09:48 AM
ironworks's Avatar
It might be worth cutting a whole in the hood, for the added low end torque a stock 5.3 manifold would provide.
Old 04-16-2008, 10:01 AM
Supporting Vendor
I'm not sure about the 5.3 but the injectors may not fit the LS1 intake.
I did a 6.0L and the truck injectors would not physically fit the LS1 intake/fuel rails. You can get "take out" injectors off LS1's all day long on Ebay or the LS1 forums.
Old 04-17-2008, 09:58 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
I've got an LS1 intake and tb, you can have it if you want it.
Old 04-17-2008, 10:01 AM
Stang's Bane Stang's Bane is offline
That right there speaks to how good the LS1 intake is...
