Old 12-13-2004, 01:40 AM
Default Recipe for Pro-Touring
Here is one way to whip a fresh Pro-Touring basket of goodies:
Take one 67 Camaro-
http://www.pro-touring.com/~tylerb/5.jpg
Shake well, until all loose, old, crusty suspension falls out-
http://www.pro-touring.com/~tylerb/6.jpg
http://www.pro-touring.com/~tylerb/7.jpg
Add two parts of Wayne Due suspension-
http://www.pro-touring.com/~tylerb/8.jpg
Put Wayne Due sub on a flat sheet-
http://www.pro-touring.com/~tylerb/10.jpg
Dump contents of 67 Camaro onto subframe-
http://www.pro-touring.com/~tylerb/11.jpg
Take 1 tall deck big block, 2 engine plates, and a McLeod modular bellhousing and sprinkle them onto the front end-
http://www.pro-touring.com/~tylerb/12.jpg
http://www.pro-touring.com/~tylerb/13.jpg
(Note some firewall clearance may be needed. In case of engine setback, subsitute factory pedal mounting with Tilton unit)
http://www.pro-touring.com/~tylerb/14.jpg
For optimal results, place engine behind front axle centerline-
http://www.pro-touring.com/~tylerb/15.jpg
For a topper, try adding a set of 20x10 and 20x13 wheels-
http://www.pro-touring.com/~tylerb/16.jpg
When placing in oven, make sure oil pan does not hang below frame rails-
http://www.pro-touring.com/~tylerb/17.jpg
Take Wayne Due brackets and place welder on tack for 15 min-
http://www.pro-touring.com/~tylerb/18.jpg
http://www.pro-touring.com/~tylerb/19.jpg
http://www.pro-touring.com/~tylerb/20.jpg
Blend Guldstrand components-
http://www.pro-touring.com/~tylerb/21.jpg
Slide rear into sheet with Camaro and Subframe-
http://www.pro-touring.com/~tylerb/22.jpg
Serve with loads of horse power-
http://www.pro-touring.com/~tylerb/23.jpg
That's all for this edition of Cooking with ATS .
Please join us next week for more baking and preperation secrets.
Tyler
Old 12-13-2004, 05:45 AM
Steve Chryssos's Avatar
I like looking at pretty pictures. Thanks. Where do the forward links of the rear suspension mount? I assume you will open up the firewall, yes?
________________
Steve Chryssos
Ridetech.com
Old 12-13-2004, 06:09 AM
The 4 link portion mounts to a bracket not yet welded in. It goes between the frame rail and the inner fender.
The firewall and tunnel will be removed for this car.
It is coming along nicely. As soon as the other 3 wheels/tires show, I'll pop it on the ground for a nice look, then off to the body shop for a few months.
Tyler
Old 12-13-2004, 06:40 AM
61Bubbletop's Avatar
61Bubbletop 61Bubbletop is offline
Lateral-g Moderator
Cool!...I those half shafts are ready for battle against the torque of that big block!....nice work.
Old 12-13-2004, 06:53 AM
I have a pair of Carbon Fiber half shafts on the way, along with full Guldstrand camber kit, 4 link bars, and tie rods. It will hold as long as those 20 wheels never hook!
Tyler
Old 12-13-2004, 07:03 AM
Lateral-g Moderator
Excellent....will really be a neat car when completed.
Old 12-13-2004, 09:10 AM
Musclerodz's Avatar
Very nice Tyler. Awesome work.
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 12-13-2004, 09:23 AM
BC69's Avatar
BC69 BC69 is offline
Looks great...keep us posted. You gotta be getting more and more excited by the day.
Tim
In memory of those gone before us
In gratitude for those who care.
Old 12-13-2004, 09:38 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Awesome, you'll have to keep us in the loop. When is the expected delivery date?
My LS7 69 Camaro
Old 12-13-2004, 10:40 AM
DCreations DCreations is offline
Tyler,
Does that Tilton unit Come with a gas pedal also?
