Old 12-15-2004, 09:28 AM
MaxHarvard's Avatar
Default w00t it works!
Vinyl paint works!! Duplicolors flat black vinyl and plastic paint!
No primer needed, no cracking... no flaking, i couldnt even scrape it off it my finger. in my quest to change my interior to black, i'm lucky i found it!
Works on both vinyl and plastic and you can see here!
Old 12-15-2004, 09:31 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Cool. Now how about those seats? When are you going to get them in the car?
My LS7 69 Camaro
DCreations DCreations is offline
Cool man, How many coat's did it take?
Dave
“Tony Tony Tony, I know that your horny, but there’s
somethin bout that Bush ain’t right”
MaxHarvard's Avatar
When i get the car back :p
Old 12-15-2004, 09:32 AM
MaxHarvard's Avatar
Believe it or not, just 2 light coats for the plastic... and one for vinyl... it soaks it right up... crazy.
Old 12-15-2004, 09:39 AM
jonny51 jonny51 is offline
I wonder how the paint will hold up to general wear and tear and friction on the seats.Keep us posted I would like to know.
Old 12-15-2004, 09:44 AM
MaxHarvard's Avatar
Not sure on the seats, i wont be painting the front seats, because they are already black.. but the back seats i'll try it and keep you posted.
Old 12-15-2004, 11:43 AM
68protouring454's Avatar
Default vinyl dye
i always use rubbing alcohol toclean plastic/ vinyl theniuse a adhesion promoter so it sticks and stays,the apply ver light coats generally 2-4 coats,sem makes a great vinyl dye in spray bomb or mix and spray,looks good max,did you use any adhesion promoter??
jake
Old 12-15-2004, 11:56 AM
BC69's Avatar
BC69 BC69 is offline
That did come out better than Id ever think those would work. What color was it to begin with??
Tim
In memory of those gone before us
In gratitude for those who care.
Old 12-15-2004, 03:38 PM
Musclerodz's Avatar
I use SEM. The stuff holds up pretty well but since it is not a permanent dye, it will need touched up from time to time. It is definitely cheaper than having it recovered and looks just as good.
Mike
Mike Redpath
Musclerodz & Customz
facebook page
