Old 08-25-2008, 09:22 AM
**67camaro **67camaro is offline
Default Billet gas/fuel door for a 67 camaro
Hi - Anyone out there know where i can get a Billet fuel cap/door for my 67 camaro ?
Mark
Old 08-25-2008, 11:17 AM
Musclerodz's Avatar
Mark
cap Marquez design/ door nothing out yet that is bolt in
Mike Redpath
Musclerodz & Customz
facebook page
Old 09-07-2008, 06:16 AM
Cheers mate ,
I've located a polished aluminium fuel filler cap that simular to an aircraft type , it's lockable , has a six bolt pattern and is 94mm in dia , hose i.d. is 52mm.
It's made in the UK , I sourced it from Earl's fittings down here in Australia.
Mark
Old 09-07-2008, 09:31 AM
Roberts68 Roberts68 is offline
Any part numbers or a link would be hugely appreciated
Old 09-08-2008, 02:03 AM
I used ATLs 3" cap. Not an "bolt on" but quality is high
http://www.atlinc.com/US/home.html
us dealers : http://www.atlinc.com/US/dealers.html
63 Z06
Old 09-08-2008, 04:43 PM
Y-TRY Y-TRY is offline
What's different, if anything, on the filler-tube side?
Old 09-22-2008, 08:30 AM
The part number of the one i purchased is #A36NL2 , it has a lead free flap fitted , vented and lockable.
I have spec sheets on this cap which has all measurements and different options. They are to large to upload - so if any one would like the spec sheets , email me at [email protected] and i email you the spec sheet.
I took a couple of pics , a bit blurry.
Its looks simular to ATLs cap - I have't fitted it yet , but i just got to drill six mounting holes thru rear panel , then join filler cap to tank with either a 2" i.d. 90 degree bent rubber fuel hose or use a 2" tube with two rubber fuel filler neck joiners at each end (and make sure the tube is earthed to avoid static electricity).
