Old 10-04-2008, 09:32 AM
final cut final cut is offline
Default Aeromotive Regulator
Aeromotive A1000 injected bypass regulator pn 13101. New in box, never used, retails for about $120. Give me $50. & a little for shipping from Wa. and its yours.
Old 10-04-2008, 10:00 AM
camcojb camcojb is offline
if it's the 13101 efi regulator I'll take it.
Old 10-04-2008, 10:57 AM
sold!
Old 10-04-2008, 02:16 PM
makoshark makoshark is offline
Darn it!
Old 10-04-2008, 02:39 PM
Originally Posted by makoshark View Post
Darn it!
sorry man, I needed it.
Old 10-04-2008, 02:43 PM
I need it too. That and to learn how to design/plumb a fuel system in my 67
Old 10-04-2008, 10:13 PM
BBC69Camaro's Avatar
Same here
Old 10-04-2008, 10:41 PM
a search should find a lot of good tips on plumbing an efi conversion. I do it differently than a lot of people, but I do what works good for me; I prefer to put the regulator at the back of the car; simpler, less plumbing, no heat-soak issues with hot fuel being bypassed to the tank.
Might be a good idea to start a new post in efi with any questions you have.
Old 10-04-2008, 11:55 PM
Thanks for the suggestion.
I actually have tried a bunch of searches; it seems that an external pump on a carb is less common. I started a post since I currently I am trying to figure out my external electric fuel pump setup for a carb (eventually want to go EFI):
https://lateral-g.net/forums/showthread.php4?t=16798
Old 10-05-2008, 04:37 AM
Thanks, I just posted a thread in the engine section. Hopefully that will clear the dark clouds in my mind over this fuel system
