Old 01-29-2009, 08:15 AM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Default Resivoir for hydro brake system
any ideas? I need 3 outlets and it has to be vented. something that mounts on the core support or inner fender.
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 01-29-2009, 08:42 AM
deuce_454's Avatar
you need an outlet for the pump (if you arent using a standard saginaw pump) and one or two returns.. (if you run one return you will need to use a tee fitting to connect both the steering and booster low pressure returns..)
Jake: Hit it.
Old 01-29-2009, 09:01 AM
bigtyme1's Avatar
I have the pump that came with my march pulley set up.
69 RS Ragtop
[email protected]
Old 01-29-2009, 09:23 AM
deuce_454's Avatar
i made that same mistake:-(
i believe it can be fixed by tee'ing from the low pressure return to the bottom outlet of a single outlet reservoir on the radiator core support level with the march reservoir... that way you are increasing the available volume...
Jake: Hit it.
Old 01-29-2009, 09:37 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Mark, somebody makes the exact reservoir that you're talking about, it's a really nice, fabricated piece... but for the life of me, I can't recall who makes it.
My LS7 69 Camaro
Old 01-29-2009, 09:44 AM
VP23271's Avatar
VP23271 VP23271 is offline
I know Kugel Komponents makes a single, double and triple reservoir, but I don't know if it would work for your application or if it has enough capacity.
I was planning on using the single for my hydraulic clutch.
http://www.kugelkomponents.com/produ...cessories.html
Rick
"Better to Be Lucky than Good "
Old 01-29-2009, 04:47 PM
bigtyme1's Avatar
Billett specialties said they have a few but I want to make sure I'm getting the right thing.
69 RS Ragtop
[email protected]
Old 01-29-2009, 08:00 PM
novaracer novaracer is offline
http://www.pscmotorsports.com/reserv...c-161_223.html
I have this one its very nice...
BC
