Old 04-05-2009, 03:45 PM
murtah's Avatar
murtah murtah is offline
Default T56 Slave quick connect?
How far into the connect receiver on the GM slave does the master connect fitting go? I have the ATS supplied master and slave.
I hooked it up but the male end only went half way. I can push the connector all the way in but it rebounds to half way. Is half way correct?
I have inculded a photo. The hyd line is wrapped with a fire sleeve.
Old 04-05-2009, 06:15 PM
murtah's Avatar
Where is everyone today? No 6 speed owners on the net today?
Old 04-15-2009, 05:48 AM
XcYZ's Avatar
XcYZ XcYZ is offline
It's been a while since I messed with it, but I'm pretty certain that's how mine is, too.
My LS7 69 Camaro
Old 04-15-2009, 06:03 AM
Payton King's Avatar
Default That is correct
You can see the white sleeve. To remove it, you push that sleeve in with a special tool or a screwdriver, if you are real careful. If it went all the way in you would not be able to get it to release.
I guess I am going to reply behind everything Scott posts today.
