Old 06-23-2009, 09:47 AM
Swain's Avatar
Swain Swain is offline
Default Early T56 to a pre 85 SBC
I have a 383 I am building and want to hook up a early LT1 T56 to it. What will I need?
Jay
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 06-23-2009, 01:48 PM
GeoffP GeoffP is offline
It depends on which direction you want to go with the T-56. OE or Aftermarket. OE will mean you'll need a complete T-56 setup including the clutch assembly (make sure it's complete - the T bolt isn't avail from GM anymore). Depending on if your block/crank is pre or post 1986 you could also need a special flywheel. Pre-86 is 2 piece rear main as I'm sure you already know and will require a different flywheel.
If you go aftermarket, you can use a traditional clutch setup, flywheel, etc.
I hope this helps. Let me know if I can answer any LT1 clutch setup questions. I've done a couple of them.
Cya!
GeoffP
68 Camaro LS1 T56 3.55 12 bolt posi
Old 06-23-2009, 01:54 PM
Swain's Avatar
Thanks for the info, I am going with OE it has the clutch and everything still I guess I would need to find out what fly wheel I am going to need.
Jason Swain
Old 06-24-2009, 10:31 AM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
See if this helps: http://www.nastyz28.com/~Todd80Z28/p...56_Install.htm
Search over at nastyZ a bunch of guys have done it.
Scott from NJ
Old 06-24-2009, 10:40 AM
JamesJ JamesJ is offline
You will need to get the "special" flywheel, you can look it up at Summit.
James J.
Old 06-24-2009, 03:10 PM
Swain's Avatar
I looked on summit they only had one for a BBC. I will have to call some people up.
Thanks for all the help guys.
Jason Swain
Old 06-24-2009, 04:54 PM
1HTBRRD's Avatar
1HTBRRD 1HTBRRD is offline
Try calling Mcleod's tech support, they were extremely helpful and knowledgeble when I had questions on which flywheel and clutch to use. Good luck, it's the best thing I ever did to my car
1962 Nova, LS1/ T56, DSE Mini tubs and subframe connectors, Church Boys 4 link, Viking coil overs, C6 brakes
Old 06-26-2009, 05:44 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
You could also search Mcleods message board, it's been asked a few times.
Centerforce, Hayes, Zoom and a few others make the flywheel you need.
Flywheel will work with either BBC or SBC. Only diff is internal or external balance.
Old 06-26-2009, 10:44 AM
A buddy of mine did this and used Centerforce's flywheel. As far as I know he's never had a problem.
GeoffP
Old 06-26-2009, 10:47 AM
Swain's Avatar
Ok ill check them out thanks.
Jason Swain
