Old 07-01-2009, 05:46 PM
speedshftr speedshftr is offline
Default powerglide to 350 trans questions
im changing the powerglide to a 350 trans in the camaro.will the flywheel that is on the engine now work with the 350 trans?anything else i should be aware of?i know the 350 isnt the greatest but till funds get rite itll have to do
thank you
the car is a small block ,if that matters
Old 07-01-2009, 06:19 PM
zbugger's Avatar
zbugger zbugger is offline
It's a straight bolt in swap, if I remember correctly. I think all you need is a converter and a new kickdown cable, and the dipstick. I think all the other measurements are the same.
Lost in a hopeless world on a path that wanders aimlessly and endlessly... As if it really even mattered.
Old 07-01-2009, 07:06 PM
camcojb camcojb is offline
you are correct, super easy swap. Crossmember, driveshaft and yoke, etc. all work. You will need to mod the shifter to get low gear, or buy a shiftworks conversion for your stock shifter, or most any cable type aftermarket shifter will work.
Old 07-05-2009, 09:20 AM
all went well/very easy swap.i need a shifter and a flywheel cover.thank you everyone.my trans just has the nub coming out the side for the gear selector.what type of linkage attaches it to the shifter?what and where can i buy the part?
thanks eveyone so much.
Old 07-05-2009, 10:09 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
What type of shifter are you going to use? They make universal linkage kits.
Old 08-12-2009, 09:07 AM
70rs's Avatar
70rs 70rs is offline
If you are going to use a stock type shifter, that bracket that attatches to the trans can be found in almost any wrecking yard or tranny shop. If you are going aftermarket shifter, most come with a bracket and cable set up. Let us know how it goes.
