Old 08-27-2009, 05:06 PM
rogue rogue is offline
Default Full Racepak Digital Dash or a full set of Autometers...
Was looking at some of my options for proper gauges and working some numbers
Covan Thunder Road Dash 239.95
Autometer Carbon Oil Pressure 69.95
Autometer Carbon Oil Temperature 55.95
Autometer Carbon Water Temperature 79.95
Autometer Carbon Voltage 47.95
Autometer Carbon Fuel Level 49.95
Autometer Carbon Vacuum 65.95
Autometer Carbon Speedometer 249.95
Autometer Carbon Tachometer 169.95
Total Covan Thunder Road Dash 1029.55
Anvil Auto Dash 299
Anvil Auto Panel 2 Gauge Panel Insert 69.95
Total Anvil Dash 1158.55
Both setups are quickly approaching $1200 territory when all is said and done, I could easily do a comparable racepak setup.
Reggie Jackson's camaro has a STUNNING interior and I really like the look of all the autometer carbon stuff
Then again, the data logging and GPS features of the racepak units is great for track days.
DSE Blank Aluminum Dash 575
Racepak IQ3 Logger Dash 1393.99
Total DSE/Racepak Dash 2338.69
Stielow's Camaro X
When all is said and done, how much money am I looking at for a racepak dash with the comparable capabilities of the autometer setup.
Old 08-27-2009, 05:11 PM
ironworks's Avatar
Racepak.
Old 08-27-2009, 05:23 PM
Racepak.
Have you guys worked with the units quite a bit? They're nice units and It'd get a lot of use at track days.
Do the lap timers work via gps? set the beginning of the lap by marking the finish line type thing?
They look like cool units.
Old 08-27-2009, 05:33 PM
ironworks's Avatar
Most of my experience is drag racing with the racepak. But I was reading the IQ3 Manual yesterday and it is just a matter of pushing a button to set the Start Finish location. The Racepak website has lots of info.
Rodger
Old 08-27-2009, 05:58 PM
Musclerodz's Avatar
What do you have for engine? That will really depend on what the Racepak wil truly cost. The cool thing is if you are running efi and have the right ECM, you can datalog direct from the ECM with a CAN connection and not have to buy a bunch of senders or extra guages. If not, then the Racepak senders are not cheap and can drive the price through the roof.
Racepak has several diplay pages so you can decide what is primary, secondary, etc. We will be using their other dash pak in a build we are just strating and will be pulling info direct from the ECM to reduce costs.
Mike Redpath
Musclerodz & Customz
facebook page
Old 08-27-2009, 06:33 PM
Another option is the AIM Sports Strada MXL unit...
$1099
Old 08-27-2009, 06:36 PM
I'm going to have to add sensors for everything. I'm not running any ECU or EFI currently... I was considering leaving the Digital dash to track type duties and only hooking up track critical info like Oil Pressure, Oil Temp and transmission temp.
I can use my existing console to house the typical 4 gauges, fuel, volts, water temp, oil pressure.
So I'd really only need 3 sensors. The gauges can do the rest
Old 08-27-2009, 06:56 PM
mexMan's Avatar
mexMan mexMan is offline
I'd go with the set of Autometers, I just love the way they look, retro, and cool, dunno, I've never been fan of digital racepak dashes... I would use them for function, but in this case is for looks too, so I would go with the AM's
''Every car has a great quality, is not the hands that build it, is the dedication behind it.''
Old 08-27-2009, 08:02 PM
Steve1968LS2's Avatar
The Stack dash is around $1400 - $2000 (depending on options) and you don't need any auxilary guages.. It does oil pressure, oil temp, voltage, tach, speedo, water temp and a few other ones --- all in one unit. Although I'm not sure if the data logging is extra $$$.
Maybe I'm just old but I prefer the analog tach..
http://www.stackltd.com/streetdash1.html
Stack ST8130M Street Dash Display Max
The ST8130M is the first road legal dash system to feature Predictive Lap Timing. This is the perfect system for racer who's vehicles must be street legal and for any enthusiastic track day participant.
The Street Dash Display Max system is supplied complete with mounting brackets, switch kit, mil. spec professional wiring loom, manual and all sensors (except Fuel level) to provide the following functionality:
Tachometer
Speedometer
Odometer & Trip meter
Oil & Fuel Pressure readout
Water & Oil Temperature readout
Volt Meter
Fuel Level
Infrared Lap Timing
Peak Value Tell-Tales on all monitored parameters
Intelligent Alarms on all monitored parameters
Separate low fuel level light
Optional plug in Shift Light
Fully sealed against water and dust
1 year competition Warranty
Suitable for all negative earth ignition systems
Old 08-27-2009, 08:39 PM
XcYZ's Avatar
XcYZ XcYZ is offline
This is just my opinion, but after driving Camaro X for close to 1,000 miles on Power Tour a few years ago, I found the Racepak to be... ok. It was trick and has some great features, but what I wasn't a big fan of was the digital number displays. You needed to read the numbers and digest the data instead of simply glancing at a needle. I know that sounds odd and a lame excuse, but after years of just being able to glance at a needle and knowing whether things are ok or not, it was an adjustment. That being said, some inputs on the Racepak can be configured to display as an analog (like the tach, speedo), the Racepak looks especially bad ass at night, it's programmable, and it's something that's outside the box.
Pros and cons.
Oh, and here's an obligatory Camaro X / Racepak pic. Camaro X is such a bad ass car.
My LS7 69 Camaro
