Old 12-15-2005, 01:14 AM
71OLDS's Avatar
71OLDS 71OLDS is offline
Default New Member 71 Olds 442 Conv
Just joined the site will fill in details on my 442 tomorrow. Pics are on website if it shows up..
-Joe
http://geocities.com/rcktpwrd/Joe442.html
Joe Lincoln
1971 Olds 442 Convertible & 1970 Cutlass Supreme
Old 12-15-2005, 01:36 AM
71OLDS's Avatar
71 442 Convertible - Original #s match block
468 , Edelbrock heads ,Torker, 425 7” rods, diamond pistons, 10.17:1 CR
Studs & Main straps 7 qt oil pan 750 QJ
Bullet Solid Roller: 276/288, 112, .643/.643 (1.65), 246/258 @ .050
Hooker SC 1 7/8" tubes 3 1/2" collector, 3 ½” to 3” reducer ,Dr Gas 3" in 2.5” out X-pipe , Dynomax 2.5” Mufflers, 2.5” tailpipes and modified Olds trumpets
Be Cool Alum Radiator w/dual elect fans
Richmond 5 speed (Road Race trans w/custom gears 3.04, 2.13, 1.57, 1.24. 1.00)
McLeod – “street twin” clutch & SFI approved scattershield
Chevy 12 bolt posi 2.73 gears,Moser Axels, TA Perf girdle cover
Rear Suspension: Hotchkis adj upprs, SSM lift bars lwers, 1” drop Hotchkis springs, air bags, 1” Hotchkis sway bar, QA1 12 way adjustable shocks
Front Suspension: QA1 Pro Coil Over system w/12 way adj QA1 shocks
Hotchkis tubular upper control arms, Global West tubular lower control arms, Hotchkis 1.5” Hallow sway bar, B Body tall spindles
Brakes: Baer 13” rotors front, Baer 12” rotors rear, Baer dual diaphragm booster, Hurst roll control
AGR Steering box
Aeromotive fuel pump w/sumped stock tank
18x8 ARTT2 Front rims - 255/45/18 Nitto 555
18x10 ARTT2 Rear rims - 305/45/18 Nitto Drag Radials
Stereo: Alpine 9805 CD player w/removable face plate, front speakers = high output Boston Acoustics Pro Series 5 1/4” split channel – replaced Custom Autosound speakers inside the kick panels, flush mounted 5 Ό”” Bouston Acoustic CRX57 2 way speakers in the rear. 2 x 10” 100 watt JL Audio subwoofers and a 500x5 watt JL Audio amp kit in the trunk to add some extra power to the system.
Joe Lincoln
Old 12-15-2005, 04:28 AM
McssGmachine's Avatar
McssGmachine McssGmachine is offline
Default 71 olds
Look awesome!!!!!!!!!!!!!!!!! Welcome.
Old 12-15-2005, 06:29 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Awesome car. Welcome aboard.
My LS7 69 Camaro
Old 12-15-2005, 07:44 AM
RussMS's Avatar
RussMS RussMS is offline
Sweet Ride!
Russ
Old 12-15-2005, 08:40 AM
71OLDS's Avatar
Thanks Guys!
She's been off the road for a while for the motor rebuild (new specs above) and the coil over add on w/the Baer brakes, new gauges in the interior, & some fiberglass parts (front fenders, rear deck lid, front bumper etc). The car and I used to be at 4200 lbs w/the stock cast iron heads & manifold and the stock steel body parts. She went on quite the diet (now the car & I are 3975 lbs)!! I won't have it back until the snow thaws in spring. Then I will have to redo the paint.
Joe Lincoln
Old 12-15-2005, 08:41 AM
hotwheels's Avatar
hotwheels hotwheels is offline
welcome to lateral-g joe, that is one beautiful car you own.......wowza
1992 mustang gt twinturbo'd
1988 mustang gt bottlefed
2004 mach 1 resting in garage
1989 mustang coupe 4 cyl.
1980 mustang coupe 4 cyl.
MY MUSTANG ENTHUSIASTS SITE
Insanemustangs
Old 12-15-2005, 02:26 PM
907rs's Avatar
907rs 907rs is offline
Welcome! If you hang around here long enough, you'll be broke in no time.
Bill
Old 12-15-2005, 04:18 PM
Rybar's Avatar
Rybar Rybar is offline
I love it! Your car is awesome! I have a sweet spot for olds, especially ones done as nice as yours!
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 12-15-2005, 11:08 PM
71OLDS's Avatar
Thanks again guys for the kind words.
I also have to say thanks to Scott. I sent him pics and a tech sheet on my car this afternoon and he's already created a web page for me in MEMBERS.
That was fast!!
Joe Lincoln
