Old 07-01-2010, 07:15 PM
Default Richard Barbara's 67 Camaro
HI reading through this in the members rides section it says the rear is narrowed. ANyone know the length flange to flange? I like the look of the rims in the back and hoping to see if I can get close to this look,
Old 07-02-2010, 09:06 AM
BA. BA. is offline
I don't know but I've seen his pics and it does have a GREAT stance to it.
69 Rally Sport - LS7 and stuff
Sponsored by VISA/Mastercard
Old 07-03-2010, 09:45 PM
67ragtp 67ragtp is offline
I highly suggest that you set the wheels and tires in the car and measure flange to flange, all these cars are a little different. Looking back at my moser reciept, it says the axles were done at 26-5/16 33 spline with the big torino bearing. I think the overall flange to flange is 54", Ive got a 1/4 inch spacer on it to bring the wheels out a bit more to clear the leaf springs. There's plenty of room in the wheel house, the leafs are the problem. The wheels are budnik fontana's 17x11 with a 5.250 back space with 315s.
I cant wait to rip those leafs out(got to finish the red car first) and install a multi link design rear suspension. Although you guys like the stance on the car and I thank you for that, there is no adjustibility in it. Something with an adjustable coil over and you can dial in your stance any where you want it. BTW those are DSE 3 inch drop. For a leaf spring car it does handle pretty sweet(rides pretty stiff)
Hope this helps - Rich
Old 07-03-2010, 10:28 PM
It does look sweet!
Old 07-04-2010, 07:50 AM
Thank you Rich! Are you running a OEM subframe? If so what are the forn specs? any issues with Brake interferance?
BTW I al going with a G link or a Torque arm.... No leafs for me either way...
Love your car !
Old 07-04-2010, 10:17 AM
Thanks- Yes it is an OEM sub, with the full DSE treatment solid body bushings frame connected, coil over relocation/koni's /600lb springs /hollow hotchkis bar. No problem with brakes fitting. I had the pbr style baer track up front with 13" rotors inside, 17x8w/4-7/8 back space and 245s(stock spindles/.8 deg neg camber/ 5.5deg positive caster). I switched up for the 6 pot wilwood superlites but only because the rear was a beotch clocking the Baer calipers with the integrated parking brake mechanism. I must have 3 sets of caliper brackets here trying to make that baer system fit properly, it always seemed to hit the leafs somewhere. Since the wilwood set up has the parking brake shoe's inside the rotor hat they worked out perfect, superlite 4 pots(love the hydraboost killer brakes).
The g-link is a great choice good luck with your build, if there anything else you need give a shout- Rich
Old 07-04-2010, 09:40 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
I agree. I'm running 18x11.5's with 5.4" backspacing and 335's. I ended up ordering a 54" flange to flange rear end from Moser. I, too, may run a 1/4" spacer.
Chris
Old 07-05-2010, 05:57 AM
I agree too guys.. but.... I don"t have a rear... or the rear suspension.... I want to order the whole thing at once>> Typically get a better price that way :-)
Old 07-05-2010, 06:06 AM
Lexus(sorry dont know your name?)
What we mean is pick/purchase your wheel and tire combination first, then set them inside the rear wheel houses and measure across from mounting pad to mounting pad. Take into consideration the thickness of your rotor hats for final dimension.
Rich
Old 07-05-2010, 06:33 AM
Rich
OK that makes sense.. sorry up early fishing... got skunked.. it fogs my thinking sometimes
