Old 08-10-2010, 09:29 AM
tellyv's Avatar
tellyv tellyv is offline
Default water temp sending unit
The water temp gauge in my cuda reads 20 degress cooler that it actually is, how can I fix this? The company went out of buisness so getting another sending unit is'nt very easy. Any help would be great. Thanks Telly
Old 08-10-2010, 11:03 AM
XcYZ's Avatar
XcYZ XcYZ is offline
What company, Telly?
My LS7 69 Camaro
Old 08-10-2010, 12:46 PM
tellyv's Avatar
nordskog
Old 08-10-2010, 12:58 PM
HRBS's Avatar
HRBS HRBS is offline
stupid question.... how do you know its 20 degrees off ?
Here is an easy way to check.
If you have a thermostat in the water neck and you know what it is (say 180), with the car cold, fill the radiator to the top and leave the cap off. Start the car and have someone tell you the moment the temp gauge reaches 180. At EXACTLY 180 the thermostat opens, and fluid starts flowing. The level will visually drop a little and you'll notice bubbles forming from the current of fluid. The thermostat doesnt lie. This will tell you exactly how off the gauge is. If the gauge is inaccurate you should be able to use any sender as long as the ohms are correct. (assuming it is an electrical gauge)
HRBS on Facebook
Old 08-10-2010, 01:46 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
I bet it's the same sending unit they all use.
Your local Napa might even have it.
Old 08-10-2010, 04:54 PM
tellyv's Avatar
I have a cap with a thermostate in it, and the fans kick in at 180.
Old 08-11-2010, 06:27 AM
marks914's Avatar
marks914 marks914 is offline
Regular User
I think Nordskog used a Faria temp sender, 450 ohms at 100F
Most gauge companies (including us) get their temp senders from Faria
Mark
www.newvintageusa.com
Old 08-11-2010, 01:43 PM
tellyv's Avatar
Mark
Thanks can I get one from you?
