Old 11-21-2010, 06:47 PM
Van B's Avatar
Van B Van B is offline
Default Carpet tips and tricks?
I have never liked the way my carpet fit in my car. It was a Camaro specific cut pile kit from one of the vendors my interior guy uses.
I have noticed that the DSE cars always have nice looking carpet. Tight and smooth and it fits very well. I asked Stacy about it when I saw her at Goodguys Chicagoland. She said they did a lot of prep work with the Dynamat prior to carpeting. I should have asked her to clarify what she meant.
How do I achieve that nice look? I assume lots of high quality glue is one thing.
Jeff
99 Miata LS6
67 Camaro Street Fighter 599 HP L92-SOLD
Old 11-21-2010, 07:40 PM
Roadbuster's Avatar
Roadbuster Roadbuster is offline
Warm it with a heat gun (carefully) from the back side and it will form into place easier. This is for those problem areas where there is a bubble, needs to form around something, etc. When it cools it will hold that shape.
Jon U.
1968 GTO - SC&C's suspension
1967 911 - a few modifications
Old 11-27-2010, 09:04 AM
Sales@Dutchboys's Avatar
I would say they do a good job with dynamat and then the interior guy uses a jute pading..which helps cover any wires or bumps you might have in the floor. also maybe check with an interior shop on some good carpet like a square weave or a mercedes carpet maybe.
Paul
dutchboyshotrods.com
269-823-2967
Old 11-27-2010, 07:39 PM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
Its all about the prep work, Install the dynamat smooth as you can then your padding has to lay right then the seams need to be sewed in the right places to get it to follow the floor right. On a lot of the cars we do I fuse aluminum over the dips and then put the dynamat down, Makes for a really nice looking carpet. Don't use crap carpet!
TRACY WEAVER
www.recoveryroominteriors.com
Old 12-01-2010, 06:54 PM
billetman's Avatar
billetman billetman is offline
In the August 2010 edition of Rod and Custom magazine there is an article named "Keeping Your Cool"(pages 40-49)that shows how to cut, shape and install Dynamat and related products. Hope this helps.
Old 12-01-2010, 07:17 PM
BBC69Camaro's Avatar
I was just going to say it would make for a good article how to work in insulation something like Dynamat with carpet.
Any ideas if that edition is still on the news stands? About to start on insulation myself soon after I paint my floors.
Old 12-01-2010, 07:39 PM
pavell's Avatar
pavell pavell is offline
A trick I've used for every car I have done is use a soldering iron to burn through when making holes for the seats; as it does not fray and looks clean.
