Old 11-23-2010, 09:47 AM
snowskater6996's Avatar
snowskater6996 snowskater6996 is offline
Default brake help
Its probably a long shot but does anyone know what size the banjo bolt would be on a C6 caliper? I have been to 3 different auto parts stores and nobody carries them or even knows the size they are. Thanks
"Nightmare"- 1972 Dodge Challenger
Daily Driver- 1994 Trans Am
Old 11-24-2010, 05:36 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Do you want to know the thread size?
Old 11-24-2010, 08:43 AM
yea thread size or if you got a part number that would be awsome. thanks
Old 11-24-2010, 09:30 AM
MarkM66's Avatar
Have you tried 10mm x 1.0 ?
I think that's what I used on some C4 calipers.
Have you tried to see if they have them at a Chevy dealer?
Old 11-24-2010, 10:37 AM
That's what I figured was that it was m10x1.0 but the parts store didn't carry any. My chevy just opened up yesterday from an owner change so I havnt tried yet
Old 11-25-2010, 09:56 AM
Ppd1979 Ppd1979 is offline
Found these part numbers on ls1tech
banjo bolt 22163795
banjo bolt washer 10139097
Old 12-01-2010, 09:47 AM
Apogee Apogee is offline
Just to confirm what was noted above, the thread size and pitch of the C4/C5/C6/LS1 F-body banjo bolts is M10x1.0. You should be able to get a Dorman #13912 at any auto parts store with access to Dorman parts or their "Help" products.
Tobin
KORE3
www.kore3.com
Old 12-09-2010, 10:41 AM
Tobin
KORE3
Thanks for that part number. One question though, when I look it up it says that its for the rear? would that make a difference if put on the front caliper?
Old 12-10-2010, 10:04 AM
No difference front to back as far as I know.
Tobin
KORE3
www.kore3.com
