Old 02-02-2006, 02:30 PM
Jerebus67 Jerebus67 is offline
Default Any one versed in decoding block #'s
http://photobucket.com/albums/e143/jerebus67/?sc=3
Can someone help me run the #'s on this block. T1108HB
The date on the cowl of the car is 12C.
He said he ran the #'s of the motor when he bought it and it is an original SS350 drivetrain car. Can someone help me confirm this is the matching motor?
My 67 Convertible!
ZZ4, DSE front rear and minitub
http://photobucket.com/albums/e143/jerebus67/?sc=1
Old 02-02-2006, 02:42 PM
HB is a 69 350 / 300 code. it is probably a 386 (last 3 numbers) casting number. It should have a VIN on it also. If the last 6 of the second set of number match the last 6 of the VIN (not the trim tag), Your iynn like flynn
Old 02-02-2006, 02:52 PM
Do you know where those codes should be on the block?
My 67 Convertible!
Old 02-02-2006, 06:08 PM
Bill Howell Bill Howell is offline
Site Sponsor
69 and older cars, it should be on the pad on the front of engine. This is where the other number you posted above was right? Should be located on same pad. The numbers you posted are usally 1/4" size, the other one is 1/8 size. Or visaversa, I am having an old age moment right now.
Bill Howell
www.americanstreetcarseries.com
Old 02-02-2006, 09:12 PM
Also, the VIN could be located under the car on the raw engine casting on a vertical pad just above and in front of the oil filter
Old 02-03-2006, 07:01 AM
promax/vennom#16 promax/vennom#16 is offline
Default Web Site?
would there be a web site out there with this information? I have a similiar situation also. I have a 396 (T1201IV Front Side) ( 3902406 Rear Side )that I would like to know what it came out of, And I also have a buddy that has a 67SS and he would like to see if his #s match. Year one says you can find the info on it's web site, but i have had no luck locating it?
Dave
VENNOM NOVA UNDERCONSTRUCTION
Old 02-03-2006, 07:21 AM
mdprovee's Avatar
mdprovee mdprovee is offline
Camaros.net has a section for decoding numbers. Very knowledgable people.
Mike
Old 02-03-2006, 07:25 AM
XcYZ's Avatar
XcYZ XcYZ is offline
MorTec is a great resource.
My LS7 69 Camaro
Old 02-03-2006, 08:27 AM
Default Yearone
Thanks Scott, i'll look at that one also. I looked at YearOne again and located there page.(I'v been there several times and could never find it , but today was my lucky day.)
http://www.yearone.com Scroll to Engine I.D. and Codes
Dave
Old 02-03-2006, 08:39 AM
Default Some help?
The only thing i could come up with was;
T= Tonawanda or Flint Mich.
11= November
08= Day of Month
HB= 350cid/300hp/1969 CamaroSS
Hope this was some help
Dave
