Old 01-06-2012, 03:24 PM
game-over game-over is offline
Default detroit speed ls1 gas tank?
http://www.detroitspeed.com/1967-196...fuel-tnks.html
i have heard horror stories about ricks tank and rock auto ... doesnt seem that many people are running DS's tank....
any advise...
i have a 69 camaro, dropping ls1/6 speed/
hoping for 400+whp
Old 01-07-2012, 10:28 AM
1HTBRRD's Avatar
1HTBRRD 1HTBRRD is offline
I'm running the rock auto spectra tank with a 5.3 LS putting 333hp to the rear wheels and have had zero issues.
1962 Nova, LS1/ T56, DSE Mini tubs and subframe connectors, Church Boys 4 link, Viking coil overs, C6 brakes
Old 01-07-2012, 10:56 AM
214Chevy's Avatar
214Chevy 214Chevy is online now
Originally Posted by game-over View Post
i have heard horror stories about ricks tank.....
Not sure about that. I've had a Ricks tank for 6 years and I'm about to buy another one. I vouch for them. But, DSE makes damn good products too.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 01-07-2012, 06:00 PM
Z06vette's Avatar
Z06vette Z06vette is offline
I'm running a rick's tank in 69 camaro with LS1/T56 406rwhp. It's narrowed, notched, and has the check balls added to the pickup assy. Had it about a year and 4000 mi. The only problem I have is the fuel gauge doesnt work most of the time. They sent me another, different style, at no charge. That one doesnt work either. Fit, finish, and function have been top notch. Not sure if others have had any trouble with the gauge. Scott
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 01-07-2012, 07:12 PM
realcoray realcoray is offline
Pretty sure DS is just a re-branded rock valley tank. Rock auto, which is NOT rock valley, sold the spectra tanks that have had the most issues. The typical ricks or rock valley tank have issues with starvation because of a lack of good baffling but lots of people run them ok.
Old 01-08-2012, 06:14 AM
NAPA 68 NAPA 68 is offline
And I thought it was me. I figured I screwed something up on my 59 Bel Air. The gauge works sometimes. Then, after I shut the car off, it won't work again.
Old 01-08-2012, 04:07 PM
My guess is you have bad ground.... The senders work on 0 to 90ohms... and are sensitive to bad grounding.
The float system just acts like a rheostat in the circuit... but if you're ground side is bad - then you're going to have a hit or miss system. If you've undercoated the car - and then have rubber in between the hanger straps etc - and haven't run a ground strap to the tank - that could be an issue... You don't want to rely on a braided hose to carry the ground...
Old 01-08-2012, 05:35 PM
Musclerodz's Avatar
dse and ricks have had a simliar issue with venting, but not with starvation. Spectra premium has had starvation issues. New vaporworx tank by ricks and soon by dse solve all issues but there is a cost that goes with them.
Mike Redpath
Musclerodz & Customz
facebook page
Old 01-08-2012, 06:30 PM
Z06vette's Avatar
I too figured it was a ground problem. However, after multiple tests, switching grounds around, trying another guage, etc... I finally ran a strand of wire from the neg bat terminal to the tank-- still same thing. I fill up and gauge still reads 1/4 tank. 2 days later it goes to 3/4 or maybe even full. 100 miles later its still on 3/4. I have gotten so used to using the trip meter that I harly even look at the gauge. After running out of gas in Tennesee on the powertour I don't know I'll ever trust it again. I even took the sending unit out of the tank & hooked it up- works the gauge prefectly when i move the float by hand. I think the issure is by having all the baffling in the tank, the float arm can only be so long or it his the baffling. The short float arm does not seem to work as well as the longet ones found in most production tanks. At least thats what conclusion I have come to on my own. I am no expert or rocket scientist... if you have any other ideas I'm open to them. Or maybe I just ended up with 2 bad sending units.
69 RS LS3/T56
67 RS LS2/T56
Old 01-08-2012, 11:00 PM
The short arm / float just might be the issue... since you've checked your circuit. I'm out of ideas.
