Old 05-15-2013, 08:04 PM
usa-69z usa-69z is offline
Default front backspace
New rims are here ! Im curious to what backspace guys are running up front.. The back space i ordered are virtually flat ,, I did use same measurements from my last set of rims ,, they work fine but the look is mmmmmmm
I ordered my fronts with 4.75 b/s 245/40/18 and there virtually flat (no dish),, not diggin the look to much. I have speedtech front upper and lower A arms with coilovers..
could i have gotten more dish up front?
what are others running?
69 CAMARO - RIGHT HAND DRIVE AUSSIE MODEL.
383 SBC 8 STACK INJECTED EFI.
RIDETECH FOUR LINK REAR - DSE MINI TUBS .
SPEEDTECH FRONT A ARMS & COILOVERS.
MOSER 3.7 REAR- 6 SPEED T56 TREMEC.
FIKSE RIMS ETC ETC..
Old 05-15-2013, 09:17 PM
RENN SCHNELL RENN SCHNELL is offline
I assume you have an 8.0" wide wheel?
What brake package and hubs are you using?
Old 05-15-2013, 10:07 PM
8 inch rim with standard disc/calipers,,
Old 05-16-2013, 04:31 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
What wheels?
Sounds like they made them with a thick pad. To clear the calipers.
How much room is there between the wheel and the caliper?
I agree, I'm not a fan of that look.
Old 05-16-2013, 05:46 AM
Mark , i havnt fitted the fronts up yet as im working on a 4 link rite now..
after some research im seeing that the 'tru turn' system from ride tech seems to offer an alternative,,..the only thing im not a fan of is the 2 inch drop spindles you must run,,, dosnt that move the lower A arm much closer to the road? i really need to get some dish up front...
Originally Posted by MarkM66 View Post
What wheels?
Old 05-17-2013, 08:47 AM
craig510's Avatar
craig510 craig510 is offline
I guess I'm out numbered here but I don't like deep dish rims. It puts a bunch of extra load on the lip of the rim for no good reason. Depending on the offset it will force a compromise on scrub radius and puts additional bending stress on the bearings.
Old 05-17-2013, 04:20 PM
Rybar's Avatar
Rybar Rybar is offline
Yeah your front Fikse wheels with those specs will not have a big lip on them. It's just the way they are. Look at mine they are the same.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 05-17-2013, 09:08 PM
yep Ryan , we are in the same boat with this,,the tru turn system sounds interesting , but as mine is right hand drive im not sure about fitment..and drop spindles im not a fan of..
