Old 11-12-2013, 08:10 PM
fishface's Avatar
fishface fishface is offline
Default Wheel spacer questionable
Hi all, I searched this and didnt find the exact answer I was after so looking for some expertise. I have a Chassisworks subframe to go in a 69 Camaro in the spring. I bought it out if a stalled project and it had the Baer brakes with it. Long story short it will take a 5/16 spacer to keep.the inside spokes from contacting caliper. This is a street only car and I am planning to use 1/2 inch ARP studs. Many have said not to space over 1/4 and wanting to be safe above all else and would go with different brakesif necessary.I cant use adapter type and maintain correct backspacing. Any advice??
Old 11-13-2013, 01:57 AM
Vince@Meanstreets's Avatar
I ran a 5/16" spacer for many years with no issues. just have to make sure you torque the wheels correctly and check them ever so often.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 11-13-2013, 05:26 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
With those studs, I wouldn't worry about, just make sure they are long enough.
Old 11-13-2013, 08:27 AM
Apogee Apogee is offline
Your rotor is basically a ~5/16" spacer, right? No worries there. As for an additional spacer, just be sure to use a high-quality, 6061-T6 aluminum spacer and you should be fine. Avoid the cheap die-cast aluminum spacers like the plague...they have the annoying reputation of failing when you least want them to.
Tobin
KORE3
www.kore3.com
Old 11-13-2013, 05:37 PM
fishface's Avatar
Thanks for the replies! I will.go.for.it and use a good quality spacer and studs.
