Old 12-25-2014, 06:09 PM
Default GM Clutch Actuators
Gents,
I'm going to measure to determine if a LS7 clutch actuator GM 24237634will work on my set-up, but I need to know the height (Base to bearing surface) as well as the compressed height. Does someone have one laying around they can measure one for me?
Thanks,
Old 12-28-2014, 07:26 PM
spode's Avatar
spode spode is offline
I have one can't get measurements at this time. Here a thread on the corvette forum that shows the compressed and extended lengths.
http://www.corvetteforum.com/forums/...5-preload.html
Jeff
Old 12-28-2014, 09:28 PM
Jeff
Thanks for the link. The exact reason why I need the measurements. That guy must not have measured for the two bearings he destroyed. He should have had a hard time bolting them together. That bearing was smooshed in there
Old 12-29-2014, 08:34 AM
dontlifttoshift's Avatar
Posted for reference
24264182 - 98-02 LS1 F Body Slave Cylinder
Extended 3.470"
Compressed 2.890" approximately
Supposedly the Shelby GT500 unit has more travel in it, or a shorter compressed height. There are a handful of guys running them with T56s and Centerforce Dyads.
Donny
Old 12-29-2014, 02:39 PM
Extended 3.470"
Interesting. Do you have the part # by chance?
Old 12-29-2014, 03:22 PM
Let me look
Donny
Old 12-29-2014, 03:37 PM
Let me look
The GT500 slave....
Old 12-30-2014, 11:15 AM
You should be more pacific....It may have been posted in Stielows build thread, I don't have it.
Donny
Old 12-31-2014, 07:12 PM
Ill send him a note. I did see it in his build thread, but no part #.
Old 04-01-2015, 09:08 AM
Just wanted to add this information here. Randy Johnson at D&Z turned me onto this through his conversations with centerforce.
05-10 mustang GT oem number 4R33-7A508-AA or Sachs number SB60225
Extended 4.000"
Compressed 2.550"
That's another .340" of compression over the stock F body CSC.
My setup is LS, Dyad, stock 98-02 bell and a t56 magnum. I only had .160" of travel left. This will give me a full .500" and should be plenty for the dual disc.
This will be a little different on plumbing and there is not a bleeder port, I'll update when I get that all figured out.
Donny
