Old 02-12-2015, 01:23 PM
REAL BOB JOHNSON REAL BOB JOHNSON is offline
Default vintage air?
Little unhappy with there customer service. I have vintage in 8 different cars and is the only company I have used and I need a heater core and they won't sell me one without buying a whole evaporator box for $470.00 ? I'm done I will not go back
Old 02-12-2015, 05:18 PM
Ketzer's Avatar
Ketzer Ketzer is offline
That really sucks. If you have a NAPA anywhere close, they still have paper catalogs and the heater cores are listed by dimension in the back... of course you will have to beg to see a paper catalog, then blow the dust off of it...
Jeff-
Old 02-12-2015, 06:11 PM
Boss 5.0's Avatar
Boss 5.0 Boss 5.0 is offline
I am shocked with as much business you have done with them that they won't help you out.
Clearly they have forgotten what customer service really means.
Copper Hill Rod & Custom
1955 Chevy BelAir
1951 Chevy 3100
1987 Chevy R10
Glenn
Old 02-12-2015, 08:23 PM
130fe 130fe is offline
Unhappy
Sad to hear, I also had a less than desirable experience with their tech/sales guys last year. I needed another glove box and an adapter for my center dash vent to finish my install. I found the part numbers out of their catalog and was going to order through Summit. Summit told me that there would be a 3 week lead time for them. I figured I would just call VA and cut out the middle man. Over a 3 week period, I tried calling them and left several voice mails. Never got a return call from the voice mails. I got lucky and got through via phone call one day. The sales guy was ok, but when I said I had left a few voice mails and not received a call back. He said they were "busy". Really.....
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 02-13-2015, 07:23 AM
dontlifttoshift's Avatar
The heater core really isn't a service item. The only way to replace the core is to destroy the case as it is all glued together.
No different than many oem parts now. On some applications, you can't replace a ball joint or bushing, you buy the control arm.
Donny
Old 02-13-2015, 11:56 AM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
I have been going back and forth between Vintage Air and Classic Auto Air for about a year. I have no experience with either company but a good friend of mine is a 30+ year ASE Master mechanic and he has been pushing me toward Classic because he has had bad customer service experience with VA. This thread just reinforces everything he as told me about VA.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 02-13-2015, 01:04 PM
Swain's Avatar
Swain Swain is offline
Pretty sure Vintage Air makes all the Evp Boxes for their competitors. They own the tooling.
I've had nothing but great service. How old was the heather core?
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 02-13-2015, 07:40 PM
Ketzer's Avatar
Thanks Donny, I didn't know it was permanently glued together... and that sucks even more for Bob.
Jeff-
Old 02-13-2015, 08:19 PM
The air box is glued together and I cut around the core and pulled it out had a small leak where the tube sodiers to the main body brazed it up and is good as new. This car has been built about 3 years and not driven much
Old 02-14-2015, 01:59 AM
Vince@Meanstreets's Avatar
there you go, hot rodder fix!!
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
