Old 07-12-2015, 08:14 PM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Default Wilwood brakes advice
Got my 69 up and running....I have 4 wheel disc brakes, Wilwood 6 piston in front and 4 piston in the rear. My question / concern is this, Wilwood says the pads need to be bedded. Is it normal for the brakes to sound like you ran over a Bobcat? The car has not been on the road yet, but moving it around the shop has me bit worried.....the brakes makes a terrible screeching/howl when applied. Is this normal until the pads have been bedded? Need advice. Thanks
Old 07-12-2015, 08:51 PM
Sound coming from all 4? Sounds only when brake pushed? Did you shim the brackets?
Different pads make different sounds depending how aggressive they are, but I don't see them making excessively more noise prior to bedding them in.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 07-13-2015, 06:10 AM
NO they should not sound like that! EVER....
Get it up in the air so you can see the back side of the rotors - my guess is you have a bolt in a caliper that is up against the rotor! You should see it quickly because it's probably already left a witness mark.
Old 07-13-2015, 06:24 AM
DKz Garage's Avatar
Did not shim the brackets at all, the sound is when you apply the brakes...
Did not shim the brackets at all , just the calipers to center them on the rotor
I will check the back side of the rotors, but I did make sure that the caliper bolts were not digging into the rotor when I assembled them. The noise comes on when you apply the brakes. Not sure what to make of the noise...
Old 07-13-2015, 06:29 AM
Check to see that one of the pads isn't installed backwards....i.e., that the back of the pad is up against the rotor... don't laugh... it happens!
Old 07-13-2015, 10:23 AM
dontlifttoshift's Avatar
Check all the things that Greg said.
Black e coated rotors? That's how they sound when new. Bed the pads in and they will be fine.
Donny
Old 07-13-2015, 10:43 AM
DKz Garage's Avatar
Pads are in correctly....and you are right, it could happen Thanks for your input...
Yes, Black e-coated rotors, am I glad to hear your response...... I was in panic mode. I'm trying to get the car done for the Car Craft Nationals this weekend and this had me pretty worried.....
Old 07-13-2015, 03:41 PM
Any obvious scarring or marks? I'd check that fully before saying it's just the ecoat. Glad that is a potential cause. Just dont wanna see brake failure rushing to make an event.
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 07-13-2015, 09:17 PM
DKz Garage's Avatar
Amen to that! Took the car out with my tuner and after a few heat cycles on the brakes, the noise disappeared.
Old 07-13-2015, 09:36 PM
That's great!
Texas A&M BSME 2008
1992 Corvette ZR-1
