Old 10-12-2015, 01:08 PM
paulk68 paulk68 is offline
Default mast motorsports oil pan
I am going to run the mast motorsports oil pan on my LS3 carte engine. I have heard it works well with the ridetech tru-turn on a stock first get clip. can anyone confirm? are you happy with the pan? does it take a stock LS3 windage tray? also any dealers on here for MAST?
thanks
Paul
Old 10-12-2015, 01:49 PM
MaxHarvard's Avatar
thanks
Paul
I've had two of them, both worked perfectly as designed.
Can't comment on the compatibility but it works just fine with the stock windage tray and comes with a new oil pump pick up. Reuse the stock gasket and you're good to go.
I like that it uses a stock oil filter and has a built in remove oil cooler lines
Old 10-12-2015, 03:29 PM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
Tom Farrington is a Mast dealer. [email protected]
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 10-12-2015, 06:05 PM
MattG's Avatar
MattG MattG is offline
I'm running it with tru turn and have no issues. I'm running dirty dingo sliders with the engine as far back as possible, but I have tons of room from the tru turn center link.
The Mast pan is a really good one, but it you plan on doing a lot of road course events, I would go with the Autocraft Pan. It has much better baffling and is a proven unit in road course applications.
I only do autocross for the most part and have had zero issue. I also talked with Stacey Tucker at DSE about the Mast pan and she never had a problem with it in her '69 Camaro.
Hope this helps,
Matt
'69 Camaro Coupe, Full Ridetech stage 3 suspension, moser wavetrac 12bolt, Forgelines, Ls3 Heads/Cam,T56 Magnum. Built by me and tuned by Ed!
'69 'Vert Camaro: DSE Sub-Frame, DSE Mini-Tub, DSE Four-Link w/9inch. LME LS7 427, T56. Tuned by Ed Hutchings, :SOLD!
Old 10-12-2015, 10:29 PM
Nativefx Nativefx is offline
Hope this helps,
Matt
Does anyone know whether the Autocraft oil pan will clear the tru-turn? I'm also curious about whether the Autocraft offers enough strength to the block compared to a cast pan (I read somewhere they were structurally important)?
Old 10-13-2015, 08:20 AM
MattG's Avatar
Don't know for sure, but comparing the measurements, it should fit just fine. Never seen a single complaint about the Autokraft pan, so structural support isn't an issue that I've heard of. In fact, never heard of Any aftermarket pan reducing structural integrity. It's a solid unit.
Old 10-13-2015, 12:43 PM
72Z/28's Avatar
72Z/28 72Z/28 is offline
You could speak to Kurt at Autokraft (17158745921). He is very helpful
72 Camaro RS:SOLD
68 Camaro:
LS6 Engine,Tremec TKO 600,5 Speed
Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors, FIKSE FM5s
Old 10-13-2015, 10:19 PM
I've got an AutoKraft pan on my motor, it's a nice piece.
Old 10-19-2015, 06:28 AM
Thanks guys, I am ordering the Mast pan through Tom Farrington I appreciate all the help.
