Old 10-13-2015, 09:50 AM
NOVA NOVA is offline
Question Will a 325/30/19 Tire Work on a DSE Mini Tubbed 3rd Gen Nova
Nova 3rd Gen Mini Tubbed - looking at 325/30/19 Michelin Pilot Sport tire as an example (19X11 Wheel) I hear and see some 335's, I am going a bit smaller hoping for no issues - - Michelin Pilot Sport tire example - This is a street car, driver.
Feedback / questions Please.
Thank you
Forgelines - Ridetech - DSE Tubs - ZZ4/700R
Old 10-13-2015, 12:02 PM
Vince@Meanstreets's Avatar
If you nail the back space it can be done. You may get some rubbing on the inner tub while going into a drive way.
Set to clear 5/8" from the outer quarter lip. There is a raised portion just above the lip that you have to clear but since its a large diameter wheel with a low profile aspect tire you should be fine. I have been closer than that (1/2") with no issues.
The only other part you will have to watch is the lower shock mount and bracket.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 10-13-2015, 02:19 PM
Ketzer's Avatar
Ketzer Ketzer is offline
Tub it. That other stuff can wait.
Old 10-13-2015, 03:17 PM
Thumbs up
Thanks for the feedback
Thank you
Old 10-20-2015, 07:33 AM
IndyNova's Avatar
IndyNova IndyNova is offline
I've got an 18x8.5 with a 275 tire on a lowered stock suspension 69 Nova. Rubs a little on the inner, but not bad. Will be mini tubbbing this winter to fit a 335 tire
https://facebook.com/Protour69Nova
69 Nova-Ridetech, LS
Old 10-20-2015, 04:31 PM
Question tubs
Nice, it will look killer with the wide meats back there. what wheel size (18 or 19 ?) will you be going with after the tubs are installed ?
Old 10-21-2015, 04:16 AM
IndyNova's Avatar
I will be doing dse tubs and will prob go 19x10, it really all depends on what my budget is at that point.
Old 10-21-2015, 11:23 AM
Jakespeeds Jakespeeds is offline
I have a 73 Nova SS with custom 15 X 8 Rally wheels in the back all tucked with no rubbing issues. But it was not easy with the leaf springs in the stock position. I had to make custom lower spring shackles that moved the shock mounting position up an into the wheel a bit. Took some fiddling but it worked. Of course this was done back in the 90's before I had ever heard of DSE.
Jake
After much research, consideration, and experimentation, I have decided that adulthood is not for me. Thank you for the opportunity.
Old 01-25-2016, 05:56 PM
Yenko68 Yenko68 is offline
I have a 70 with 15x7 and dunlop 255/60/15. When I take any turns with speed the outer lip shaves the side wall. I'm running GM rallys so I'm sure the back spacing is off. I thought I measured it once and only measured roughly 10.5" from lip to inner fender well
