Old 12-05-2016, 08:29 PM
Fastbowtie Fastbowtie is offline
Default DSE Subframe and American Racing Torque thrust IIs
Has anyone used American Racing wheels torque thrust IIs and the 67-69 DSE Subframe? I have the z51 brakes and my current 17x8 4.75 bs torque thrust IIs hit the calipers. Help!!
Old 12-06-2016, 04:47 AM
dhutton dhutton is online now
Pretty sure you need an 18" wheel with Z51 brakes. It has nothing to do with to with your subframe. You might get away with base C5 brakes. Tobin has the fit templates for both on his Kore3 website.
Don
Old 12-06-2016, 06:40 AM
Don
Well I'm also wondering if a bigger rim can fit up front with a 255 tire. Also the reason I wonder about the back spacing is the wheel fits up to the bump in the hoop. If that was further in it might work.
Old 12-06-2016, 11:03 AM
DSE answers your question here, it is year dependent:
http://www.detroitspeed.com/1967-196...mini-tubs.html
Print out the fit template from Kore3....
Don
Old 12-06-2016, 01:43 PM
Musclerodz's Avatar
The way the spokes are made I dont think they will clear the z51 caliper
Mike Redpath
Musclerodz & Customz
facebook page
Old 12-06-2016, 04:00 PM
Don
I will Don.
Old 12-06-2016, 04:02 PM
Yea but what if you increase the pad?
I forgot to mention, that my calipers are touring classics so they have the corvette name milled flat.
Old 12-06-2016, 04:30 PM
Same as decreasing the backspacing. What is the backspacing and width of your current wheel?
Old 12-06-2016, 07:00 PM
17x8 4.75
Old 12-06-2016, 09:18 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
I'm running 18x10 275s with a 6.6 back space on my DSE sub with C6 Z06 brakes. These wheels were ordered with a thick mount pad. Not sure if that helps you or not. But I can tell you that the 18x10 275s fit the fenders and inner wheel wells with no modifications.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
