Old 08-03-2006, 11:48 PM
69camarofast 69camarofast is offline
Exclamation best way to replace motor mounts?
Hello everyone..i was wondering what would be the best and fastest way to remove and replace motor mounts when engine is in car..sm350..Thanks
Old 08-04-2006, 06:19 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Use an engine hoist to hold the motor up while you replace the motor mounts one at a time.
My LS7 69 Camaro
Old 08-04-2006, 07:29 AM
Cool motor mounts
Thanks Scott, i will work on it after work today..im trying to get my sons Camaro ready for a small car show Sat. we are helping with regis. and lucky enough i do have a small hoist..i will try that..thanks again..Chris
Old 08-04-2006, 02:05 PM
Blown353 Blown353 is offline
Engine hoist works great... another option is to cut a large piece of thick plywood (1" minimum) and use it and jack under the oil pan. Make sure the plywood covers the entire bottom of the oilpan or else you run the risk of denting it and changing pickup-to-pan clearance.
1969 Chevelle
Old 08-05-2006, 10:49 PM
Cool update
update..i replaced the linkage and the motor mount was bad on drivers side..i used the hoist..it was tuff getting that bottom bolt on..thanks for all your help
