Old 08-05-2017, 07:19 PM
Default Old school air intake
Anyone know if you can buy this ?
Old 08-05-2017, 07:23 PM
randy randy is offline
No. It's custom
Old 08-05-2017, 07:32 PM
slimjim's Avatar
slimjim slimjim is offline
why not a holley single plane intake setup? similar to what don hardy uses on his LS engines? I'm curious why it isn't more popular on retro builds
NC
streamline 68 camaro
Build Thread here
Old 08-05-2017, 08:25 PM
Meh not for me... I like the ls3 efi just also like this air intake look as well
Old 08-05-2017, 11:03 PM
sd67 sd67 is offline
I really tried to find that too as I want to run the old school look with my LSX 454, I have been kicking around this:
http://www.delmospeed.com/product/th...y-adapter-ls3/
http://www.jegs.com/i/Chevrolet-Perf...44033/10002/-1
The height is a challenge, probably 11 inches from the deck of the motor, which I am not sure will fit even with the 2 inch cowl hood.
If you find someone that will do the custom version with the stock intake like the photo, then count me in for one too.
Old 08-06-2017, 12:19 AM
slimjim's Avatar
Is that to adapt your current throttle body?
I just looked, there's a lot less options for the LS7 unfortuneately, I think the height of the setup you're suggesting will be around 9" for an LS3. If I go this route I'll be using this.
https://www.holley.com/products/fuel.../parts/112-587
But I must admit I havent done my full homework yet.... or built the LS3
NC
Build Thread here
Old 08-06-2017, 04:21 AM
If I had built an LS engine, I would have done this to keep my shaker functional and looking correct. I tried to do this for my LT but no one modifies the intakes any more for port EFI. Port EFI is the only way I'd do a carb style intake on top of a modern motor.
Old 08-06-2017, 09:25 PM
Yes, you turn your throttle body to the horizontal plane. I predict a 10-11 inch height which might not fit but it sure is timeless.
Old 08-10-2017, 10:12 AM
Corey R. Corey R. is offline
That intake starts life with a reproduction of the factory bottom air cleaner lid from a big block. It clips to the factory style fuel rail. The air elbow and internal baffling are custom made. The air filter element is a K&N Extreme lid. You will need the room created with a lower mount alternator and relocated PS reservoir from the likes of Vintage Air. The Corvette accessory kit from GM does not offer enough clearance. DSE also converted to SD tune to remove the MAF. I would guess they swapped the FAST intake back to a factory version for additional clearance. There are progress photos available on the DSE website under the projects section.
I imagine the reason this was used over a single plane intake was a combination of the tremendous low end power gains from the long plane runners and the desire for a one-off product that DSE is well-known for.
C.
Old 08-10-2017, 04:31 PM
Musclerodz's Avatar
Its not that high. On our last build we used the edelbrock manifold and throttle body on a 69 using factory cowl induction air cleaner.
Mike Redpath
Musclerodz & Customz
facebook page
