Old 08-31-2006, 02:00 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Default Solid body mount question
To all:
I am going to use the solid body mounts for my F-Body.
I have a choice of stock height or one half in shorter.
I was thinking however minor it might help, lowering the weight of the car would work to help improve the handeling.
Is there any known problems with this idea?
Does it change the fitting on anything else potentially?
Thanks in advance,
tyoneal
Old 08-31-2006, 06:26 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Depending on the drop, you'll most likely run into interference problems in the tunnel.
My LS7 69 Camaro
Old 08-31-2006, 08:07 AM
mdprovee's Avatar
mdprovee mdprovee is offline
When using the 1/2" shoter mounts:
I have heard rumors of fan to shroud clearence problems, if running a mechanical fan, and steering column to steering box alignment problems, if running stock type steering box and rag joint.
I dont know this for a fact, maybe someone can confirm, or deny these.
Mike
Old 08-31-2006, 08:21 AM
Rob07002 Rob07002 is offline
Not worth the potential problems that could come up IMO.
Rob07002
Old 08-31-2006, 12:55 PM
BThibodeaux BThibodeaux is offline
I went with stock height for this reason. Also FYI, if you are using subframe connectors that bolt in under the rear body mounts; to keep things aligned they will need to be shorter than the front mounts to compensate for the thickness of the connector itself. Global West does supply the shortened mounts with their connectors.
Brian T.
2011 Chevrolet Camaro Convertible
