Old 10-20-2006, 07:15 PM
KPC67's Avatar
KPC67 KPC67 is offline
Default T56
Hey guys. I have been looking around on this thread for a while and based on what i have read I am going to go with a t56 in my 67 camaro. It currently has a 396 big block with a m21 transmission. I would like to know what all is needed to make the swap, and which t56 i should go with? (viper,Ls1,lT1,modified)
Any suggestions are appreciated! thank you
Old 10-21-2006, 07:32 AM
XcYZ's Avatar
XcYZ XcYZ is offline
ATS has a FAQ section for some of the more common questions:
www.t56kit.com/FAQ/#T56_INSTALL_FAQ_SECTION
My LS7 69 Camaro
Old 10-21-2006, 07:06 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
IMHO, the easiest and cleanest way to swap a T56 into a first generation Camaro behind a traditional BBC/SBC, if you already have a 3 or 4 speed, is as follows: You will need an LS1 T56, the McLeod adapter kit (1/2” thick adapter plate that goes between the transmission and the bellhousing, extended pilot bushing, and “collar” on which the throwout bearing rides - http://store.summitracing.com/partde...5&autoview=sku), a transmission cross member (https://secure13.nexternal.com/share...unt2=827598214), a shortened driveshaft, which you can have made up locally, and an electronic speedometer or an electronic to mechanical converter (pricey!).
Using these parts you reuse your bellhousing, clutch setup, throwout fork, throwout bearing and mechanical clutch linkage.
If you are converting from an automatic, you will also need a bellhousing or scattershield for a SBC/BBC, a flywheel, pressure plate and clutch disk for a traditional SBC/BBC, clutch pedal, clutch linkage (upper rod, Z bar, and lower linkage, I’d just buy the Z bar and purchase this kit (http://www.speeddirect.com/index.aspx?nodeID=34), throwout fork and throwout bearing.
Old 10-25-2006, 09:56 PM
KPC67's Avatar
Hey thanks guys for the input, I will let you know what happens.
Kevin
Old 10-26-2006, 09:07 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
That's good info Mkelcy, .
