Old 12-02-2006, 09:01 PM
Leadfoot1's Avatar
Leadfoot1 Leadfoot1 is offline
Default Quadra Link Question
Guy's,
I need to know how the lower bar (the one that ties into the front leaf spring pocket) is mounted there. I need to know if the bar is centered on the bushing or if it offsetted? I look at pictures (and none shows it clearly) and it looks to be bushed from the outside, giving more room for the tires on the inside.
Thats what i need, i considered the air bar seriously but the bushing is centered and i don't get much more space than the leaf because of that. I could unweld and move the bar but ART says not a good idea....They should have tought about that while building their system...
Anyway, i need to take a decision. I'm now back to my first idea suspension wise, the Art Morrisson Tri-4 bar (half price at that!) if the Q-link doesn't provide the space needed.
Thanks for any help/ pics would be great.
Lead
LEADFOOT1
New for summer '13. My latest find!!
48k miles, 100% original, 1969 Camaro coupe. Untouched, never apart and squeaky clean!!! 327/th350, A/C car. Gold on black w/vinyl top. Only add ons; Fast ratio box and SS396 wheels.
FINALLY!!! A car without rust repairs ever!!! None before, none coming!!! Cant come to modifying it tough....
...So, '67 Camaro project with my laying around stuff out of my black 'vert. 468 BB and YSI blower, braked th400, 12 bolt/spool, 35 splines etc. Complete Calvert suspension front and rear. 30x13.5 ET Streets, caged, lightened, slammed and running low 9's "Street car"
Old 12-02-2006, 09:26 PM
jeff hanson's Avatar
jeff hanson jeff hanson is offline
The Quadra Link has the bushing on the outside. There should be plenty of room for your tires. I'm running 345/30-19s with no problem.
Old 12-03-2006, 07:14 AM
Leadfoot1's Avatar
Thanks Jeff!
So the bar "IS" mounted offsetted then. I'm running 345 25 20's (14.1") they should be the same. What is the Bar Bushing/ spacer bushing ratio (is the bar bushing taking like half the space and the spacer the other half?)
Any pic?
So many thanks!
Lead.
LEADFOOT1
Old 12-03-2006, 08:52 AM
XcYZ's Avatar
XcYZ XcYZ is offline
The billet aluminum bushing is about an inch wide (IIRC).
My LS7 69 Camaro
Old 12-03-2006, 01:27 PM
Leadfoot1's Avatar
Hey Scott,
Thanks, so i would get an inch of space (Good!) + the remaining space to the bar (assuming the bar is not the same width as the bushing) otherwise to the width of the bushing.
That sounds good.
If anyone has a pic it would still be cool, but it sounds interesting enough. I should get the car back this week... I'll be able to make final measurements then.
Lead.
LEADFOOT1
Old 12-03-2006, 01:41 PM
XcYZ's Avatar
You'll have a ton of space since the lower quadra link bars are much narrower than a leaf spring.
Here's the only pic I have that shows the spacer in the leaf spring pocket:
My LS7 69 Camaro
Old 12-03-2006, 02:29 PM
Leadfoot1's Avatar
exactly what i needed!!! Now i really "See" where i'm going.
'Guess Q-Link is now my next buy.... I could run it with shockwaves still....
Thanks Scott!
Lead.
LEADFOOT1
