Old 01-16-2007, 02:49 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
Default Took the 69 LSx Camaro to the Orlando 1/4 Mile Sunday...
Two runs only. Track was super busy coupled with a crash and several blown engines to slow things down.
Specs:
69 Camaro www.mcspeed.com
2000 LS1
SLP Stage III head/cam/LS6 intake/36# injectors
Long tube headers
TCI 2,900 stall
Transgo shift kit
9" with 3.5 gears
285-40-18 Goodyear EMT Runflats out back
VB&P fiberglass rear springs
Edelbrock shocks
7/8" sway bar
Car has full accessories - a/c, power windows...etc. etc. etc.
First run:
60' 2.092
1/8 8.236 89.13 mph
1/4 12.7 109.52 mph
Second run:
60' 2.070
1/8 8.121
1/4 12.539 110.74 mph
This on a full tank of gas which I figured would help with traction since I have a 22 gal plastic caprice tank fused in there that addes plenty of weight on the axle. My 60' stinks...but that is because I just rolled up in D3, rolled out on the green, then eased into it. I assume higher mph and ET (with traction) if I had sincerly launched the car. I just left it in D3 and let the computer shift.
If I could just squeeze that 60' down to 1.8 and hold it manually through red line...I think a 12.0 is not unreasonable!
The best part was leaving the track, rolling up the window, cranking down the a/c (it was over 80 degrees in Orlando this last Sunday), and cruising home with the stereo blasting, air pumping...and cruise control locked down.
Old 01-16-2007, 05:14 AM
Steve Chryssos's Avatar
Nice. Any wheelhop problems? What springs are you running out back?
________________
Steve Chryssos
Ridetech.com
Old 01-16-2007, 05:20 AM
You should have called, we would like to have met up. nice numbers
Frank Serafine
Old 01-16-2007, 05:39 AM
69MyWay's Avatar
Hey Frank...It was one of those last minute things. I'll call you next time.
Springs are just VB&P mono glass models. No wheel hop at all.
I also have not launched it really hard either. If I cam off the line over 2,000 RPM, I would be surprised.
Old 01-16-2007, 06:26 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Cool, Chris. I agree, a 12.0 should be within reach with a good 60'.
Have you weighed the car?
My LS7 69 Camaro
Old 01-16-2007, 06:58 AM
HAULNSS's Avatar
HAULNSS HAULNSS is offline
Thumbs up
Nice runs and nice setup!.
I have heard the EMT's are hard like a rock. I have no experience with them, but the Vette guys seem to dislike them from a performance standpoint.
I bit stickier tire could really pick up the 60' times, too.
Good luck!
Randy
1995 Impala SS
T56 Six Speed, Wilwoods, Tri-y's,...
1964 Riviera
31k miles
Old 01-16-2007, 11:21 AM
Steve68 Steve68 is offline
I could hear them running almost all day! should have gone but I was working on the car and house, wrecks and oil downs @ Speed world no not there
Old 01-16-2007, 12:06 PM
Rybar's Avatar
Rybar Rybar is offline
Nice runs, I say throw a drag radial on there and watch those times drop!
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
