Old 04-11-2005, 09:30 AM
Rybar's Avatar
Rybar Rybar is offline
Default LS1-T56 finally in my 69 Camaro !
Hey guys, we finally got the LS1-T56 into my car on the weekend. After 3-4 months of planning, researching, gathering parts etc it finally came together.
The install went pretty good. Had a couple of hic-ups but were minor.
There are some pics in my sig.
Next: the wiring, gauges, fuel tank install, fuel lines and all the other necessary plumbing. Going to try to have this together for this summer.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 04-11-2005, 12:39 PM
trapin's Avatar
trapin trapin is offline
Looks great...nice work.
Keep your eye on the prize and you'll be burnin' dinosaur bones before you know it.
Tony Rapin
The Pigeon Forge Project
A 1968 Pro-Touring LS1 Camaro.........and why not?
Old 04-11-2005, 12:40 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Awesome. When do you hope to be driving it?
My LS7 69 Camaro
Old 04-11-2005, 01:10 PM
Rybar's Avatar
At the pace I'm going I'd say late summer, either August or Sept.
Earlier this year I was thinking summer '06 but now it's getting closer.
1969 CAMARO RS
Old 04-11-2005, 02:49 PM
coolclassiccars's Avatar
coolclassiccars coolclassiccars is offline
i really like that red,is that transparent with a gold base? ie... tri-coat? your buddy's car sits bad a@#,that thing is sick.
Old 04-11-2005, 04:23 PM
Rybar's Avatar
It's a Candy Red (yes transparent) with a silver base. There are about 8 coats of red. It's really bright in the sun, whenever it sees it!
Yeah, Sandro's car is nuts. The car is so much nicer in person.
He posted on this site, check out his build up in the introduction forum.
1969 CAMARO RS
Old 04-12-2005, 10:17 PM
Raige Raige is offline
Default Wow
Slowly I step inch by inch step by step then WHAM its done ....
Old 04-13-2005, 02:04 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
Looking great!!!!!!!!!!!!!!!!!
Where are you going to mount the computer?
Old 04-13-2005, 09:11 AM
Rybar's Avatar
Thanks, I'm going to mount it, behind the firewall (drill a hole)
Where did you mount yours?
1969 CAMARO RS
Old 04-13-2005, 09:22 AM
69MyWay's Avatar
I made a bracket to hang it on the passenger side of the firewall between the vintage a/c unit and wall. I drilled my wire harness hole in the top of the trans tunnel (I am a freak about hiding everything).
The bracket turned out really cool because I made it to allow the computer to slip fit in place (the sides have a taper on the mount), then I have a small plate that goes on the bottom and tightens up with two nuts. It took me all afternoon one day to rough this out. If you look at the computer, there are very few options to just "bolt" it down.
BTW, what brand header is that (or homemade)?
