Old 03-28-2007, 07:11 PM
TOM NELSON TOM NELSON is offline
Default Twin Turbo Mid Engine 1100 Hp On Pump Gas
This is a all aluminum 427cid small block with Twin fuel injectors per cyl.dry sump oiling,That we made for an Ultima Gtr.It ended up making over 1100 hp at 15 pounds of boost. Heres the link. http://www.nelsonracingengines.com/v...ttrearhigh.wmv
Old 03-28-2007, 11:38 PM
californiacuda californiacuda is offline
Kick ass, whats the weight to power ratio, and is there any way to make the ratio even better(more crazy)? Have you ever measured the cars acceleration G's?
Old 03-28-2007, 11:40 PM
Can the Porsche transaxle handle the hp ok? and do you think that shift time substantially affects acclereation in a 0-100, or 0-200?
Old 03-29-2007, 05:31 AM
Payton King's Avatar
Default What block are you using to
stand up to that kind of abuse? I did not think aluminum would hold together long or am I mis-informed. Freakin' cool motor!
Old 03-29-2007, 05:39 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Tom always has the best videos.
My LS7 69 Camaro
Old 03-29-2007, 06:37 AM
The engine has some type of non aluminum sleeve for strength. With different fuels, such as 100 octane, c16, or e85 the hp could be bumped up considerably.
I think one of the major points of the announcement was that on gas available at the pump(91octane), they were able to make over 1000hp. quite an accomplishment. Demonstrates the greatness of the LS series of engines and lots of talent from the builder. Bang for buck GM rules.
Old 03-29-2007, 08:10 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
What do you mean by "non aluminum sleeve?" Cylinder sleeves? All aluminum blocks have non aluminum sleeves.
Old 03-29-2007, 08:45 AM
Default I do not believe that was an LS style motor
Looks like a regular small block chevy.
Old 03-29-2007, 10:51 AM
Default tt mid engine
I have brodix make the block for me.It use's a ductile iron sleeve.I believe they make the best cast block on the market.The engine is based on a standard sbc,The car has a modified zf transaxle but the owner has yet to lean on it.This will definetely be a puckering experience to flog in the car.Thanks for the Compliments Tom
Old 03-30-2007, 10:27 AM
Default Thanks for the info Tom
Me and one of my friends have been kicking around the idea of an 18 degree 9:1 Busch motor with a pair of turbos. I may be giving you a call soon
