Old 04-28-2005, 09:06 AM
brian905 brian905 is offline
Default Engine & Tranny combo setup (4L80E w/GM ZZ572\620) opinions?
Hey guys i have some money to trow at the motor and tranny combo and would like your input or suggestions. Im consdering the GM ZZ572\620 (620hp & 650 torque) matched with the non-electric 4L80-E, opinions? thoughts or suggestions with this setup? Thanks
Old 04-28-2005, 09:43 AM
XcYZ's Avatar
XcYZ XcYZ is offline
What are you going to put that beast into? I love how it makes 650 ft-lbs at only 4500 rpm.
My LS7 69 Camaro
Old 04-28-2005, 11:10 AM
camcojb camcojb is offline
A decently built 4L80E will handle that combo fine. I also wonder what it is going in as the tall decks are pretty snug in some cars.
You also will be able to run the paddle shifter from Twist Machine whic is super cool.
Old 04-28-2005, 11:31 AM
We were hoping it will fit the 69 camaro, but were looking into it. *crosses fingers*
Old 04-28-2005, 11:57 AM
Musclerodz's Avatar
I think hood clearance will be an issue unless you lower the motor in the car. You mention non electric which would make it a 4L80, not a 4L80 E. You would be much happier with the electric tranny being able to manipulate shift points, and as Jody mentioned, PADDLE SHIFTER!
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 04-29-2005, 08:02 AM
Steve Chryssos's Avatar
Wow. Thanks for the plug guys.
Yeah it would be a shame to eliminate the electronics from a 4L80E. Paddle shifter aside, once you have calibrated an electronic automatic to your liking, you will never go back. Expect increased performance, versatility and even reliability. Improper line pressure and shift timing can cause premature wear. The ability to install a paddle shifter is really just icing on the cake.
If a 10.200 deck height 572 becomes a problem, consider a 9.800 deck height 540. In fact you will probably be happier overall in the long run.
________________
Steve Chryssos
Ridetech.com
Old 04-29-2005, 08:30 AM
Payton King's Avatar
Default oil pan
oil pan on that motor is pretty deep. If you are going to run the car low you will have problems with ground clearence.
Old 04-29-2005, 09:24 AM
spaztikatik spaztikatik is offline
http://cgi.ebay.com/ebaymotors/ws/eB...970624530&rd=1
be a man, buy that
Old 04-29-2005, 11:13 AM
Thanks guys! great info...I will be sure to post pictures as soon as things get underway!
Old 04-30-2005, 04:47 AM
Moose Moose is offline
holy smokes..
I checked at a local dealer here that sells the crate engines and I was quoted 11400..
do some shopping before you spend 13000..
