Old 04-19-2007, 07:47 AM
JamesJ JamesJ is offline
Default Y block on fuel lines or not
If I just run the fuel line into one of my rails and then run a crossover to the other and then a line out of it to the fuel regulator is that any different then running a Y-block then a line to each rail and then two lines to the regulator?
James J.
Old 04-19-2007, 11:41 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Do you have to run a return style fuel system? I'm going to dead head my system.
My LS7 69 Camaro
Old 04-19-2007, 03:28 PM
69 L88 Camaro 69 L88 Camaro is offline
Default Efi
Can you give a little more info? Engine, pump. injector size? Batch fire or sequential?
I don't ride in it, I drive it.
Old 04-19-2007, 06:13 PM
SBC, 55# injectors, sequential, 12 psi of boost, SX fuel pump, 650 hp, will be running a return line
James J.
Old 04-20-2007, 04:56 AM
KAA's Avatar
KAA KAA is offline
I'd go with the Y and feed each fuel rail separately, in parallel, the way Aeromotive recommends. Especially if you have a big fuel pump. I plumbed it that way in a twin turbo engined car I had using the same pump as you and never had a problem.
Keith
'70 El Camino SS L78 396 - It's back!
Lateral-g Feature
Chevy High Performance Feature
'09 Viper SRT-10X
Car Craft 2009 RSE Winner
Car Craft Feature
NARRA Road America TTU Record Holder
Old 04-20-2007, 05:39 AM
XcYZ's Avatar
This car has a dead head system, made 814rwhp.
My LS7 69 Camaro
Old 04-20-2007, 07:38 AM
camcojb camcojb is offline
actually made more than that, but that idiot has no idea what he's doing! I've always preferred to Y the lines going into the two rails equally, versus running one side in , crossing over, and feeding the second rail.
Old 04-21-2007, 07:10 AM
orange88 orange88 is offline
run a Y .
helps keep fresh fuel and even line pressure on both sides.
i run a Y on my system
Old 04-23-2007, 01:24 PM
Default Fuel Delivery
I would recomend using a Y to feed the back of the rails coming out of the front into a T style EFI style regulator, returning to the tank. the large injectors and pump will contribute to hydraulic issues that you wouldn't see with a smaller system. IMHO.
