Old 07-16-2012, 08:51 PM
clill's Avatar
clill clill is offline
The problem with a Nova is it costs just as much to build as a Camaro if not more and when you are done and ready to sell it you will probably have half as many Nova buyers and will be lucky to get half as much.
PTAddict PTAddict is offline
Mark,
From the pictures, it appears that you are running the stock bellhousing, unless that was just for mockup. Is that correct? At the power levels you are making, do you not think you would want something stronger? Or is your opinion that the stock bellhousing would be sufficient in case of a clutch failure?
Also, on your transmission cooler, I don't know what transmission temps are supposed to be, but I think I just read that the Weldon pump is thermostatically controlled. Is that correct, and do you run within that window, or do you control/override it somehow?
Finally, what size lines are you running to/from the trans cooler? I would think that a heavy weight oil like that would need larger lines, but I think I read that the pump is set up for -6AN lines?
As always, appreciate the education!
I'm using this setup - Weldon pump drawing from the drain, returning through the fill, with a small FluidDyne cooler, on my D&D T56. No T-stat - just a switch. With the cooler on, temps typically stay below 200F. On a couple of occasions when I forgot to flip the switch, temps would climb into the high 200s by 10 minutes into a track session, and shifting would start to get sticky.
In "normal" driving, temps never exceed low 200s without the cooler on.
One thing we did was use a single fluid temp gauge with sensors in the diff, trans, and engine, then use a 3-way switch to select which is displayed. I'll usually monitor engine oil temp during a run, then check on trans and diff temp during the cool-down lap. I'm not running a diff cooler, and have seen 260-270 diff temps with synthetic diff fluid on hot days. Marginal, but not enough to have me figure out how to package diff cooling in my setup just yet. Oh, and don't get me started on all of the tricks we had to use to keep diff fluid from being pumped out during a session ...
In my case I'm using a QuickTime 4th-gen F-body housing. SFI rated, and still relatively light. I figure I wouldn't need it if I was confident I would never hit 3rd while upshifting to 5th - but I'm not quite that confident
Old 07-16-2012, 09:01 PM
67XR7's Avatar
67XR7 67XR7 is offline
Originally Posted by JMitch19 View Post
I can't answer for Mark, but the company I work for does some GM harness work for the aftermarket. We have found powerandsignal.com to be your best bet for higher quantity orders and mouser.com to new the best for low quantity.
Thanks!!
1970 Z28, Pm me if interested in wheel tool rental
Old 07-16-2012, 09:28 PM
BigEddie BigEddie is offline
WOW...just read through the whole thread. Can't wait to see the finished product.
Old 07-17-2012, 12:36 PM
Sieg's Avatar
Sieg Sieg is offline
The VanNus's (Dutchboys Restoration) is starting to shoot color tomorrow so I'm getting closer to getting the car back.
Mark
Old 07-17-2012, 12:41 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
So true; And starter cars aren't that far apart on price either.
Old 07-17-2012, 02:17 PM
Stielow's Avatar
Stielow Stielow is offline
People always give me a hard time for building "another First Gen Camaro". I build Camaro's because I really like them and when you it comes time to sell them they are easy to sell. I also have a ton of spare parts....
Mark
Old 07-17-2012, 04:21 PM
sokoloka sokoloka is offline
Any teaser pics of the final color choice?
Eric.
1972 Corvette Coupe - https://lateral-g.net/forums/showthread.php4?t=36573
Old 07-18-2012, 05:31 AM
Greg from Aus's Avatar
Greg from Aus Greg from Aus is offline
Mark,
Are you using a oil pump for diff cooling? if so can you let me know were you are running the return to, I'm using a weldon pump and trying to work out how to plumb it.
Greg
Old 07-18-2012, 11:44 AM
b757jetdr's Avatar
b757jetdr b757jetdr is offline
Hello Mark,
I have a quick question for you, what was the reason you went with a full roll cage (at least from the pics) vs a 4 point like you used in Red Devil?? I am in the building stages of a 69 and was going to do the full cage with enginge bay bars etc.. (not sure if thats the proper term) but I talked it over with my builder (Billy Utley) and came to the decision that for what I am going to use the car for a 4 point will work for me. I still toss the idea around to be honest as I can see my self getting this car done taking it to the track and really getting addicted to the track events. I plan to use the car for street,cruises, and some track events. I thought I remembered reading a bilp from you once that you never use anything more than a 4 point, then this car popped up so just wondered if there was a reason?
Also one last question, what did you use to wrap/cover your wire bundles with??
I love your car and look forward to seeing it come together. I am hoping to have mine close to done next summer!
Chris K
Aircraft Mechanics: So pilots can have heros too!
