Old 12-20-2016, 08:19 PM
Sonar Chief's Avatar
Smile
Originally Posted by Frankenstine View Post
Michael, looking great, is bonding the metal stronger/equal to welding ? or do you plan to weld some also? I think this is the first time I've seen anyone bond a lot of metal parts together on one of these cars.
Keith
Keith, a properly bonded part is stronger than a welded part ... the bonded sheet metal will tear before the bond gives whereas the spot weld will give way under tension. I did weld areas recommended as per the instructions.
To be a leader you need to innovate
Got the tunnel mods done, check that off the list ....
After the adhesive cures I'll finish off the tunnel mods from the bottom, still needs some material trimmed off, left it long on purpose!!!
Thanks for looking ...
