  #21
Old 01-24-2010, 04:53 PM
68protouring454's Avatar
Originally Posted by The WidowMaker View Post
jake, are you actually splitting the panel and widening the gap, or are you adding a vertical piece and then filling it in?
no, a common issue with goodmark trunks is there too small for the hole width wise. the gaps were arounf 7/16ths. we sliced the quarter 1/16th from edge, moved over till we had 3/16ths strong gap and measured, then used shear to shear filler piece that we but tig welded in using silicon bronze. metal finished to 80 grit and body worked.
goodluck
Jake's Rod Shop
