Old 01-23-2009, 10:14 PM
peetsjunkie peetsjunkie is offline
I also like the fact the ECU can control various areas, ie kill AC compressor at WOT, adjust for cold/hot temps, adjust for ambient air temp, spark timing, and so on. No matter how good of a carb you have, it cannot compare to the EFI advantages. I hated the stinky smell of a pig-rich holley, to me it's worth spending 4k on not smelling like that.
I'm pretty much sold on this kit, I just need to figure out how long it would take me to get it installed and running
Old 01-23-2009, 10:20 PM
If I wouldn't have just got my car reliable and reworked the fuel system I would be doing it tomorrow. I feel like I have to enjoy my labor for a while. I also like the idea of an aftermarket fabricated intake. Fuel injected big block is high on my priority list.
Old 01-24-2009, 05:21 AM
BBC69Camaro's Avatar
Planning on going with the Fast system for my big block. But I want to get my car on the road and all the bugs worked out first and to drive it a bit. But definitely on my list of upgrades.
Old 01-24-2009, 07:15 AM
Installaion time, if you brought a running / driging carb car to us and we did the sway, we could do it in 2 days/ But ten again, we have done a few now and have ome experiance under our belt. BUT FAST has te best instructions of all the high end systems.
When ever your ready, look into a system from us, we hve some sweet deals
Frank Serafine
Old 01-25-2009, 02:47 PM
zcrz zcrz is offline
Frank,
Whats the going rate for a sbc setup...i'll install it
Old 01-25-2009, 03:21 PM
Originally Posted by zcrz View Post
Frank,
more information required? How much of a kit do you need? Full conversion? how much horsepower? Let's start there.
Frank Serafine
Old 02-07-2009, 09:45 PM
Racehead Racehead is offline
I've been looking for any information on this exact kit for about 2 weeks now without success .... and here it is
Bill
'71 RS/Z28
468 BBC
Richmond ROD 6 speed
etc .........
Old 02-08-2009, 03:03 AM
Adam68 Adam68 is offline
Hi Frank,
Would you see a decent RWHP increase from one of these fast kits? I currently have a 540BB with 305 cnc AFR heads Dart block 9.5-1 comp etc and it has a quick fuel carb which has been set up well. the motor made 700 flywheel and is making 471RWHP in my car in Australia a few weeks ago. I was looking for a way to get around 550-600 rwhp. the motor has been built for nos and it made 870 flywheel with a 150 shot but nos is illegal on street cars in Australia.
Regards
Adam
Old 02-08-2009, 08:50 AM
Originally Posted by Adam68 View Post
Hi Frank,
Regards
Adam
Torque (especially down low) will come up with an efi swap, but HP shouldn't be much different if at all, assuming the carb is sized and tuned correctly. What efi will give you is better driveability, better mileage, easier to make tuning changes, etc. If your engine made a true 700 hp on an engine dyno there must be something different in the car config to get such a large drop in power on a chassis dyno. Was it dynoed without any accessories, open exhaust, etc? It sounds like there's something different in the two setups, like it was dynoed with open headers or a large free-flowing exhaust and the car has restrictive mufflers and a small exhaust, or maybe a small restrictive air filter, etc.
Old 02-09-2009, 03:14 AM
Thankyou for your feedback. The engine on the dyno had a 1 inch spacer under the carby and a electric water pump. The engine now has vintage air front runner set up with a normal pump and no spacer. It is driven through a t56 rockland standard gear box a mark williams tailshaft and currie tracklok rear end. In Australia our RWHP figures are always about 10% under the US due to a difference in some percentage allowance in the dynos here to over there. The car made 505hp rwhp in the same trim. I checked everything and we changed up and down jet power valves etc but the set up it had was a good as it would produce HP wise. I did leave the plugs in the car that were in it as they had been indexed and looked pretty well perfect. It is a very good engine and it is very healthy but i want another 100rwhp because a couple of my mates have blown cars and i want more power asperated. I thought about a procharger but i think that that will cause allot of messing around with the vintage air front runner set up. I could up the compression with different pistons???
