Old 11-20-2009, 08:49 AM
Ron Fox's Avatar
Ron Fox Ron Fox is offline
Come up with a plan that will make the car as reliable as possible. Putting an old richmond behind a big block pontiac probably isn't a wise choice. When I put my foot on the floor I want to feel confident that I'm not going to scatter a tranny, rear end, drivshaft, etc. So.....
What is your intended purpose for the car?
How much power do you plan to generate?
What rear gear ratio will you be running?
What highway speeds do you frequent?
I would plan on a blow proof bellhousing and a tko 600 or t56 magnum for the power you should generate out of a 455 Pontiac. Otherwise, you will eventually be on the side of the road scratching your head and wishing you put a tranny behind it that was meant to hold up to the torture. If you are a car show guy that putts around, then you can get away with almost anything.
The intended use is for the street. But listening to you guys on here talk about the autocross at places like the Good Guys shows makes me want to try it out.
Hp- 550-650??
Rear not sure.
Highway- I would like to hit the highway a cruise to different gatherings and events and weekend cruise in's, etc.
I want to drive my car and have fun with it on dry, nice days. I have had the car for 28+ years and it has been down for oh I don't know maybe 15 years so I want to drive it again.
Thanks.
Ron
1969 Firebird, 4-speed Coupe
