Old 06-23-2014, 12:33 PM
FETorino's Avatar
FETorino FETorino is offline
Sounds like Ron built the perfect pro touring car based on proven recipes.
Yep 335/285 stagger hard at work. Form over function.
Originally Posted by Matt.A View Post
All in all, I think Ron should be pretty proud. Other than the steering issue, there weren't any other mechanical issues. It wasn't fun or easy to drive. It had understeer on corner entry, mid corner, on exit and in a straight line seriously, if you weren't conscious of unwinding the wheel, the car would plow through the straights with the wheel turned until a dab of brakes or a little too much throttle made it snap. Ron worked on driving around the cars weaknesses and did really well out there, especially for his first autocross!
Sounds like Ron did just fine.
Fix the steering issue and get some seat time in the thing. Then new rear inner hoops and a 315 tire will fix you right up.
Rob in SoCal
