Old 04-27-2012, 09:25 PM
GFRDH-04 GFRDH-04 is offline
Banned
bump
Old 05-02-2012, 07:14 PM
Hydratech®'s Avatar
Hydratech® Hydratech® is offline
Supporting Manufacturer
HydratechBraking.com
Wink My finger prints
Bad ass set-up! Just got it this afternoon. Can not wait to get this in place......Thanks again to Jim and the Hydratech team!!
My finger prints are all over your parts, as I built your order personally. I am tickled that you are pleased with your goods! Especially since Detroit is home town for me. (let's go RED WINGS)
With the ABS / TCS functioning properly, you will be able to apply full line pressure to the brakes and let the computer make the rest of the decisions = retinal detachment warning!
If you would please be so kind, do let us know how it all goes for you.
If you have any questions before / during / after your installation, do please feel free to get in touch with Jim Petty:
http://www.hydratechbraking.com/contact.html
Need someone to ride shotgun for the HRPT? LOL (product testing, right!?)
Here are some Lat-G links for fine tuning:
https://lateral-g.net/forums/showthread.php4?t=15052
https://lateral-g.net/forums/showthread.php4?t=29580
There IS a difference - Thank you for choosing Hydratech!
Paul M. Clark <-- the Ukrainian - Slava Ukraini !
Founder / Master Engineer
Hydratech Braking Systems ®
Old 05-21-2012, 07:25 PM
OVRKILL's Avatar
OVRKILL OVRKILL is offline
Thanks Paul!! Got it installed this weekend minus a few details. Looks fantastic and appears factory! Will definitely read up on the tuning portion....and probably call you guys several times
If you're ever back this way, gimme a shout! Thanks again....very cool product!
'01SS - RHS 460
Fikse / MWC / Kinsler / Mast
Enough torque to buckle pavement!
"Went right past silly and all the way to stupid..." - Shawn Miller
Old 05-31-2012, 11:26 PM
Evaporate Evaporate is offline
OVRKLL,
Do you have more pics of how you routed the braided the power steering lines? I bought the Hydratech 6' braided lines kit and wanted to know how much I should cut off each line. I'm needing some reference because I have the k-member and motor out of my '96 fbody at the moment, so any help would be awesome.
Old 06-02-2012, 04:11 PM
Hydratech®'s Avatar
Lightbulb Suggestion?
I do not recommend you tackle the PS lines until you have the K member and engine back in place. Line lengths really should be custom tailored once everything else is in place (engine, rack, all underhood items), as one small little change in routing can make for quite a difference in finished line lengths. There are so many different ways to route the lines, that it becomes much more a matter of personal tastes than anything else - hold off on this until one of your later steps.
Old 06-03-2012, 03:57 PM
Thank you Paul
It looks like that is what I'll be doing at this point.
OVRKLL, your ride is killer, gotta rank as one of the best 4th gens out there.
Old 06-05-2012, 08:07 PM
ProTouring442's Avatar
I was thinking of running a Hydroboost with an electric power steering pump from a Toyota MR2.
Shiny Side Up!
Bill
Old 06-17-2012, 06:00 PM
OVRKILL's Avatar
Originally Posted by Evaporate View Post
Thank you Paul
Thanks!! To Paul's point, DEFINATELY wait until you get the engine back in the hole. I'm pretty much done with the set-up for now....just received a few more fittings from Jim and the boys to make things work a little better. Pic below is the solution to eliminate the "T" fitting suggested for the low pressure return from the unit. Punched a hole in my beautiful hydrodipped resevoir
Also decided to eliminate the power steering fluid cooler that's inline on the upper radiator hose....going to replace it with a "real" fluid cooler near the radiator. Will look 10x cleaner too
More pics to follow....
'01SS - RHS 460
Old 06-17-2012, 06:32 PM
Very clean install. Good job.
Old 06-18-2012, 05:36 PM
Hydratech®'s Avatar
Brent, it looks like you are getting closer and closer - looking good!
Bill, those MR2 and other electric pumps don't put out enough pressure and volume to properly power up one of these systems. We have worked with a few customers that have attempted this and it hasn't worked out for them. We then coached them through the installation of a belt driven PS pump to only run the brakes standalone (so that they could retain the manual steering) to get them operational...
