Old 10-27-2009, 02:57 PM
Steve1968LS2's Avatar
Default And Penny just keeps on changing...
After Optima last year we got really busy improving Penny. We added sperical bearings, ZR1 hubs, Raceseng drop billet uprights and a custom Pozzi Racing sway bar. The car was almost "reborn" since it was so much better.
Then we took the summer off from performance mods (well, except for that STACK stuff) and drove the car at events around the county.
Well, SEMA is here again so we wanted to do more to the car.. quite a bit more. Dave Pozzi cut holes, notched frames, pulled the rear and we did a host of mods to the car. We may not win again, but we're going to at least give it a good try.
Larger Baer brakes installed. Ditched the parking brake which meant the 14-inch rotors actually weigh less than the 13-inch with the integrated drum.
Front brakes fit like they were machined for these wheels. We are running a new pad from Hawk that they developed for circle track cars. They come on at 100 and last to well over 1000-degrees.
Since this is the Optima Invitational we decided to move to an Optima battery.. In this case thier 26-lb Group 51 unit. The battery tray came from www.eddiemotorsports.com and they even etched in the BP logo.
Bigger on the list was that David thought we needed more shock travel. Seems that were were on the stops durring hard turns and even on acceleration. We worked with Steve Duck over at RaceCar Dynamics and came up with a shock that's over two inches longer. The new Bilsteins are also revalved for the car. The extra length meant that we had to punch holes in the trunk floor so that this mount extender could be welded to the top of the existing brace. The top hole is for future changes if necessary. Dave sure lays down some nice welds!
Here Dave slides the new rear Bilstein shock into place. Later we scaled the car. The weight was 3290 with half a tank of gas. With a driver our cross weights are at 50/50 and the front rear are 52/48.
