Old 07-01-2008, 07:41 AM
BBShark BBShark is offline
Default Fuel Lines-Why is the return line smaller?
What is the reason for making the return line smaller diameter than the supply? I am using a 3/8 supply line and see that most manufactures use a 5/16 return. Well, I can't find much in the way of -5 AN fittings (5/16) and would like to use -6 AN (3/8) supply and -6 AN return.
Am I missing something? Any reason why this will not work?
Old 07-01-2008, 08:28 AM
camcojb camcojb is offline
should be fine. The only time you have an issue is if the return line is too small to handle the amount of fuel bypassed, and causes the fuel pressure to rise due to the restriction in the return line. If you're running a large race type pump you may need a #8 return, but the #6 should work in most all cases.
Old 07-01-2008, 08:45 AM
badmatt's Avatar
badmatt badmatt is offline
hehe so jody for my -12 feed you think i need a -10 return? lol
Old 07-01-2008, 08:54 AM
Musclerodz's Avatar
Return line is smaller because it is only returning unused fuel from the carb or EFI. The larger line will be fine.
Mike Redpath
Musclerodz & Customz
facebook page
Old 07-01-2008, 09:07 AM
I've never needed larger than a #8 return, but I've never run a #12 feed either.................
Old 07-01-2008, 10:10 AM
badmatt's Avatar
hehe yeah the -12 is a bit large but its what I need.
Old 07-01-2008, 11:40 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Damn. How much fuel pressure?
My LS7 69 Camaro
Old 07-01-2008, 11:41 AM
and how much hp?
Old 07-01-2008, 01:31 PM
BBC69Camaro's Avatar
I think it depends on the Fuel Pump manufacturer. I would run what they recommend. I know for BG they want a -8 an feed and -10 AN *return* (for BG220HR) while a comparative Aeromotive Street Rod pump wants a -8 an feed and return.
Old 07-01-2008, 03:07 PM
badmatt's Avatar
and how much hp?
shooting for 1600-1800hp
65PSI is what im thinking ill be around
