Old 05-06-2011, 07:12 PM
RBR's Avatar
RBR RBR is offline
Default Whining noise? I'm stumped.
Lq9 motor, with TKO600, New clutch and hydraulic throwout bearing.
Put it all together and started hearing a whining noise. It is loudest when idling.
I took off the serpentine belt, still had the noise.
I replaced the throw out bearing and noise with first test run. I also took out a spacer for the throwout bearing.
I push in the clutch still makes the noise?
pilot bearing looked fine?
I'm Stumped!
