Old 01-07-2012, 04:47 PM
WicKeD_SS's Avatar
WicKeD_SS WicKeD_SS is offline
Default 454 Help!
Im looking into buying a 454 and need to make sure this is the year I want... 76 Standard Deck Mark IV.... going to stroke it to a 496..... looking for 650 hp in my camaro. It was a two bolt main but was drilled to a 4 bolt with new caps.... is this going to be a problem? Need Help before its sold to someone else!
WicKeD
Old 01-07-2012, 05:55 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
That's a good block. The four bolt conversion shouldn't be a problem unless they did it wrong.
Old 01-07-2012, 06:35 PM
WicKeD_SS's Avatar
Thanks for the input! Is there any real way to tell if its done right or wrong? going to look at it tomorrow.
WicKeD
Old 01-07-2012, 06:37 PM
intocarss's Avatar
That sounds good. My old 496 with cast iron oval port heads, 11.5-12.0 comp, 1150 dom carb and a decent solid lifter cam made 635 Hp on our dyno. We converted many 2 bolt mains back in the day they worked out good..
If you can take a look at the main bearings and see how they are ask who did the work hopefully it was a reputable shop.
Maybe ask to have the block (line hone) checked by a machine shop first if it was never running after the conversion
Old 01-07-2012, 08:12 PM
WicKeD_SS's Avatar
Im going to get it tomorrow, my understanding is it was done but never put together. He did say it will need line honed. I only paid 100.00 for it seamed like that was a good price... Ill drop it off at a local speed shop and hope everything was done right before I start to put money in it. Thanks for your help!
WicKeD
Old 01-07-2012, 09:02 PM
intocarss's Avatar
Ok so they mounted the caps and left it unfinished,, was it line bored and left undersized ?
Old 01-07-2012, 10:14 PM
WicKeD_SS's Avatar
He said he has the 2 bolt caps that goes with it and the 4 bolt caps are on but will need line bored if i keep the 4 bolt caps on..... I just dont want to have problems with this block building a big 496. Thanks again
WicKeD
Old 01-08-2012, 05:07 AM
MarkM66's Avatar
I would think after the line hone, it'll be just fine.
Old 01-15-2012, 11:11 PM
Chett's Avatar
Chett Chett is offline
have the bores sonic tested too, and make sure your machine shop is reputable
Old 01-16-2012, 10:22 AM
BBC69Camaro's Avatar
X2, first thing I would do, no point if the walls are too thin (due to casting shift or whatever).
