Old 10-01-2006, 08:58 AM
Todds69's Avatar
Todds69 Todds69 is offline
Default DSE Dash Insert help
I was wonder what people are using to cut the holes for the gauges. I was thinking of using a jigsaw but I'm afraid it may bind on the 2-1/16 in. holes and warp the panel. Scott Gulbranson does a write up on it but didn't say how on the holes. I could call DSE but figured I would ask her first. Thanks Todd
Old 10-01-2006, 06:44 PM
Rybar's Avatar
Rybar Rybar is offline
Use a hole saw to cut the main holes and then a dremel to finish them. I would fasten it down good and use some wood for backing when cutting.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 10-01-2006, 07:40 PM
XcYZ's Avatar
XcYZ XcYZ is offline
I used a 2" hole saw, then finished up the openings with a small sanding drum. Worked great.
My LS7 69 Camaro
Old 10-01-2006, 11:56 PM
mazspeed's Avatar
mazspeed mazspeed is offline
If you want coolness, you can have them water jetted for precision.
Old 10-02-2006, 05:29 PM
Todds69's Avatar
Hey thanks guys. I will have to check into the hole saw. I think the water jet would be out of budget, I want to do it myself and save the dough. Besides if I "F" it up I can just be mad at myself, but if someone else did I may choke 'em.
Old 10-02-2006, 05:32 PM
Todds69's Avatar
Scott do remember the exact dimensions for the 5" gauges. Is the hole actually and same with the 2-1/16. I dont have the gauges yet and was kind of wanting to do this before hand.
Old 10-07-2006, 01:17 AM
71Nova 71Nova is offline
My 5" memory autometer tach had a smaller hole than my 5" speedo
Old 10-07-2006, 07:02 AM
XcYZ's Avatar
I don't remember the exact dimensions. I used calipers to find out what I needed.
My LS7 69 Camaro
